Trobule with non standard compliant browsers
I have buttons with mouse over effects like
<img src=pic/button/fast_right_a.png
OnMouseOver=bp(“fast_right”,“c”)
OnMouseOut=bp(“fast_right”,“a”)
height=20 width=60 border=0 name=fast_right
alt=“something”>
The old javascript worked fine in
MSIE and Mozilla
function bp(n,v){
this.document[n].src=eval(n+v+".src")}
I just wanted to implement mouse over also for
graphic input buttons.
<input type=image align=absmiddle SRC=pic/button/find_a.png
OnMouseOver=bp(“find”,“c”)
OnMouseOut=bp(“find”,“a”)
height=24 width=68 border=0 name=find
alt=“search and find”>
So I changed the old javascript against
function bp(n,v){
document.getElementById(n).src=eval(n+v+".src")}
This works very fine with MSIE
Mouse over normal images and input buttons.
But it produces only full idiotic error messages
with Mozilla 0.9.9
Error: document.getElementById(n) has no properties
Source File: file:///E:/internet/test.com/pic/layout.js
Line: 238
Has anybody here an explanation why this
won a be standard compliant Mozilla browser makes so
much trouble and how to work around this?
Roland Mösl
http://pege.org Clear targets for a confused civilization
http://BeingFound.com Web Design starts at the search engine
Re: Trobule with non standard compliant browsers
Roland Mösl wrote:
> <SNIPPED NON-STANDARD CODE>
Try using standards-compliant code??
-Mike K.
“Mike King” <mike@webcodefocus.com> wrote in message
news:3C924C89.D70B4@webcodefocus.com
Any arguments why this is not standard code?
Or is it only a troll action
Roland Mösl
> > Roland Mösl wrote:[color=darkred]
> Any arguments why this is not standard code?[/color]
“Shena Delian O’Brien” <shenacat@forget-spam.com> wrote in message
news:3C925205.93965672@darklock.com
> > news:3C924C89.D70B4@webcodefocus.com…[color=darkred]
> http://www.w3.org/TR/html401/interact/forms.html#h-17.4[/color]
There is a “src” element for input fields
Roland Mösl
1 - there is no “height” attribute
2 - there is no “width” attribute
3 - there is no “border” attribute
4 - you’re not using quotes around all your attributes
5 - OnMouseOver calls a javascript, which is not defined in any standard
6 - OnMouseOut does the same
Need more reasons?
-Mike K.
news:3C9256C7.E2B81CEF@webcodefocus.com
quotes are not necessary
they are implemented
> Need more reasons?
In the mean time, I found out the real reason why it does not work
But I think You are such a fundamentalistic evengelist
that You are complete unable to find the real resaon.
Roland Mösl
“Roland Mösl” <founder@pege.org> wrote in message
news:a6tndr$qi7$1@www.t-shirtcountdown.com
If you need quality assurance code review work done, please hire a QA
engineer. If you have trouble locating them yourself, I can provide one or
more for you on a contractual basis.
We do not do QA work for free in this group. :slight_smile:
Leonid S. Knyshov, CEO
Crashproof Solutions, LLC
Your Technology Business Partner
“Leonid S. Knyshov at home” <lknyshov@pctips.com> wrote in message
news:a6touu$te6$1@www.t-shirtcountdown.com
> engineer.
Why? Such question worked great in this newsgroup 1996 until 1999
but now, fundamentlistic evangeliststs of the clean code
mess everything up with complete sensless statment
far away from the real reasons why something does not work.
I know one or more newsgroups where I can find answers.
And for what is this newsgroup?
Roland Mösl
"Element names are written in uppercase letters (e.g., BODY). Attribute
names are written in lowercase letters (e.g., lang, onsubmit). Recall
that in HTML, element and attribute names are case-insensitive; the
convention is meant to encourage readability.
Element and attribute names in this document have been marked up and
may be rendered specially by some user agents.
Each attribute definition specifies the type of its value. If the
type allows a small set of possible values, the definition lists
the set of values, separated by a bar (|).
After the type information, each attribute definition indicates the
case-sensitivity of its values, between square brackets ("[]"). See
the section on case information for details."
“Javascript” is a language that has no formal written specification, and
is not considered a standarized language by any standards committee.
$Pot->CallKettle(“Black”); // :wink:
-Mike K.
news:3C9274A2.28E11792@webcodefocus.com
> Roland Mösl wrote:
> >[color=darkred]
> http://www.w3.org/TR/html401/about.html#h-1.2.1[/color]
As I wrote in an other posting:
You are notable to spot the real problem in my code.
You blow around some hot air, but complete unable
to find the real problem.
Roland Mösl
I could give a shit less about the problems with your code. You go
around ranting and raving about how non-standard-compliant Netscape is,
then you write non-standard code. That is my point. No go dig a hole and
die in it…
-Mike K.
ECMAScript is what was javascript and is becoming standardized…
http://www.ecma.ch/ecma1/STAND/ECMA-262.HTM
news:3C9282D4.5ED5824B@webcodefocus.com
> die in it…
This proofs again, that You are complete unable to spot
where the real failure in my code is.
The real failure has absolut nothing to do with Your list
of “failures” which are no failures.
Roland Mösl
Thanks!
I just found out some other complete unnecessary quotes
In the old form, I wasted 2 " and 1 ;
<div id=content style=“left:8;top:372;width:600;height:20;”>
Now I make a much cleaner code
<div id=content style=left:8;top:372;width:600;height:20>
3 bytes times 20 per document times 300 K page views per month
gives 216 MB bandwith saved per year
Roland Mösl
news:a6tpao$u9t$1@www.t-shirtcountdown.com
I will be frank, Roland. This letter may hurt, but it is the truth.
I am sick of hearing about one website, one problem, from one person for the
last 5 years.
You refuse to abide by the coding rules, you attempt to supercede the
standards. You refuse to properly close all your quotations. You have a
serious problem with attitude. You have a complex of superiority. That is a
treatable condition.
Let me give you an idea. I am willing to offer my help for free a few times
to my friends. I am not willing to be your QA department. I don’t think many
others here are also. This group is a circle of friends. Friends don’t work
for friends for free forever. Would you ask your friends to work on your
site for free forever? I doubt it. The Internet wipes out the borders and
distances between friends, so treat us the same.
You can hire one of my designers and get on with your life making your
opinions known with a professionally designed site. We can probably complete
it for you using your content and our layout for about $5,000 or so.
Here is my view on the current state of PEGE.org - it is unprofessional and
hurts my eyes. It has a black background, light text, the design is circa
1996. No matter how you put it, you are a programmer, not a designer.
Please, channel your energy into something more useful and stop fighting
corporate warfare between AOL and MSFT.
P.S - pay your debts. You’d think after this long you could do
something!!! :frowning:
Sincerely,
Birdra
Creator of Everglades National Parks 50th Anniversary Logo
Artboard restoration for…
“Pages from the Past; A Pictorial History of Fort Jefferson”
ISBN 0-945142-06-4
Logos - Graphics - Print Media Layout
Scott’s Buttons
news:a708fo$tli$1@www.t-shirtcountdown.com
Standards are set by software and not by theoreticall papers.
> You have a
No, I have no complex, I am.
> That is a treatable condition.
You mean much drugs could help until a complex of inferiority is reached
times
many
work
I gave in this newsgroup many valuable tips.
There had been a time where this tips had been welcomed.
But time changed, and now several people think it’s funny and
easy to bash around about some quotes instead of a real dicsussion.
It’s simple a degeneration of the newsgroup.
complete
and
I have now a designer paying his franchise fees by working for me.
He already worked over the logo and buttons on 4 sites.
PEGE is not a priority in changing.
The problem with the buttons occured, because my designer
wanted buttons with mouse over effect for the search box.
The problem is solved in the mean time by more intelligent
people able to spot the real problem and not bashing about
complete unnecessary quotes.
Roland Mösl
“Birdra” <Birdra@sesraw.com> wrote in message
news:3C93A816.A0C90879@sesraw.com
As mentioned before, I wrote several times to Hanno Schilf.
I have no idea why he does not sent You this book
Roland Mösl
news:a709tl$vls$1@www.t-shirtcountdown.com
> > You have a
I rest my case. Your Honor, I find the defendant lacking a sound state of
mind.
