Has anyone found some standard (not splined) cranks in the 140mm range
that can take trials abuse? Bent cranks are a little hard to ride on.
Chris Reeder
Chris Reeder
Re: Trials Cranks for 20" Monty
“Chris Reeder” <reed8990@uidaho.edu> wrote in message
news:39BEA3B8.52F0A8D5@uidaho.edu…
> Chris Reeder
>From a post 8/30/2000:
My son Daniel and I are buying Shimano bike cranks (left side only) and drilling
and tapping them for 9/16" pedals at 140 mm length. Cut off the excess and you
have a very tough crank at about $12 US a pair (not counting $40 for the Park
Tool TAP-6 taps). The cranks are labeled FC-C102-TY30.
Blessings!
Arthur Doerksen
Arthur,
Sounds great! A couple of questions:
Where are you getting the cranks for $6 a piece? They’re about $10 at the bike
shop, aren’t they?
How long does “really tough” last… a month?
Do these cranks have a flat length to them so that you don’t have to build a jig
just to bore a straight hole in them?
Chris
> > Chris Reeder
> drilling and tapping them for 9/16" pedals at 140 mm length. Cut off the
> excess and you have a very tough crank at about $12 US a pair (not counting
> $40 for the Park Tool TAP-6 taps). The cranks are labeled FC-C102-TY30.
> Blessings!
> Arthur Doerksen
news:39BEBB59.32F086D6@uidaho.edu…
> Arthur,
> shop, aren’t they?
$9 Canadian at a local bike shop, WHEN they are available, or $25 for the right
crank+sprocket and left crank as a set. They are the Shimano Tourney (TY30) set.
They seem to last until a drop too big. Daniel has not found out how big that is
yet with these. For the black steel Bicycle Europe cranks it is about 4 feet,
the soft aluminum Lun Chi’s about 2 feet.
> jig just to bore a straight hole in them?
They are a bit curvy, but were not hard to drill. The tough part is lining up
the tap when threading.
Blessings!
Arthur Doerksen
