Re: ah ha!
Those bags are the utmost in cool. However, they only fit one unicycle, and don’t exactly conceal what it is when at the airport. I hardly ever fly with only one unicycle, and I prefer more stealth.
For NAUCC this year, I think I will bring my usual three (when flying) cycles: MUni, 24" Miyata, 20" Freestyle. These will fit easily into my bag, along with tools, spares, and some other stuff. Though I’ll probably take the painted frames off the Hunter and Wyganowski and put them in my suitcase to protect the paint.
Here’s the essential info. about my travel bag and method, copied from one of the other threads that was linked above:
I have found a type of luggage that’s very good at holding unicycles. Since I usually fly with more than one, and only the largest of suitcases fits a 24" wheel, and I usually travel heavy, I can’t just stuff them in with my regular luggage. More realistically, I have to stuff extra luggage in with my unicycles.
So I go to one of the luggage vendors at my local flea market. There I am lucky to find a selection of the type of bag I use. Unfortunately I don’t know the name of this type of bag and I have been unable to find a picture of one on the Web after lots of searching. Oh well.
It has a flat, rigid bottom with wheels, about 18" x 24" on the big ones. Soft sides, and two zippered expanders, which will open the bag up to about 4’ tall. The main thing about this bag is that it’s big enough for a 26" MUni tire, and tall enough to fit unicycles without even taking the seat off, if you so choose.
I can get three unicycles into one of these bags, though not all with large wheels. I usually break down the cycles as much as possible, and don’t open all the expansion zippers unless I have to. The smaller your luggage is, the less likely it is to be subject to unusual forces in transit.
Always bring garbage bags when you travel. Put a garbage bag over each wheel. This does two things. It allows the grippy rubber wheel to slide easily in and out of tight spaces, and it keeps the dirt from a possibly unclean tire off everything else. Bring spare bags for the trip home, in case the originals got ripped up. They don’t weigh a thing.
As has been mentioned, never take the cranks off, because you’ll be left with axles that will poke through your luggage. You don’t need to let the air out of your tires unless you run them at extreme pressures, though letting the air out makes them fit into slightly smaller spaces. I put the pedals in ziploc bags, along with any other small parts left over.
I always bring tools and a pump, especially when traveling internationally. You don’t have to, but then you don’t get to ride until you find someone with the necessary tools and pump. I prefer being self-sufficient. So much for traveling light.
One of the nice things about normal-looking luggage is that you Seldom get asked what’s in there. But if you do, it ain’t anything with the word “cycle” in it. Sports equipment, show props, circus equipment, exercise equipment, all are the truth, to a certain extent.
Lastly, I use pieces of a camping pad. This is a piece of lightweight foam rubber you normally put under a sleeping bag for camping. I cut it in 3 or 4 squares, and put these between the cycles and to pad them against the outsides of the bag. Eventually even a crank arm will bust through strong nylon fabric. Been there.
Always assume your luggage will be treated with the utmost disrespect. If your box or other container can’t survive being dropped from a height of at least 3’ onto its corner, don’t expect it to be in one piece when you reach your destination. Remember, many flights involve changing planes at least once, which doubles the airlines’ wear and tear on the luggage.
Happy travels!
