Day 6: Flying across Huffman Prairie !!
Today I feel I had another breakthrough!
Swimming
I started the day setting a new personal record for swimming - I managed 3500 meters continuous crawl in 77 minutes - so back to the 22 minutes per km that I had when swimming 2500 meters. My 3000 meters in 57 minutes were obviously faster, but I am going for distance. I was in the pool until about 0845 today and it is supposed to be only from 0700 until 0830. There were still some old ladies in there when I left.
So my long-term goal for the summer, which is swimming 5000 meters in one session (within that 90 minute window) seems possible.
Then, after dinner, I set out to unicycle again. Unicycling in the evening while swimming in the morning was a recipe for disaster last time I did it, on 2 June (4 weeks ago already, my gosh). But things have changed since then. When I am able to balance and ride more, it is not nearly is tiring as when I couldn’t keep my balance and had to hold on to walls, ceiling and everything else. I was using a lot of upper body muscles and straining almost all my tendons and muscles, so I was sore for days afterwards, on top of being exhausted from swimming.
Now I feel much less exhausted, and also I did only one and a half hour of uni training tonight, so I am very curious about how sore I will be tomorrow - hopefully not too much. I don’t plan on going swimming tomorrow morning - it is too late for that - but obviously it is more exciting to go unicycling in the evening than to go swimming in the morning. Variation is good anyway as far as exercise is concerned.
Technicalities
So I measured the unicycle on Sunday evening, and it turned out to have a circumference of a whopping 285 centimeters, which is around what I calculated the first day based on measuring the diameter. This means I need to recalculate my riding distances
Also, I spent almost an hour fixing up my uni before riding tonight. So I ended up not starting until 22 (10 PM). I am a little disappointed that Roger at UDC UK didn’t tell me that I should have bought either a separate seatpost (http://www.unicycle.uk.com/shop/shopdisplayproduct.asp?catalogid=673) or an additional rail brakcet (http://www.unicycle.uk.com/shop/shopdisplayproduct.asp?catalogid=668) for my nightrider, since the T7 handlebar is not detachable - it is basically just an extended version of the KH rail bracket.
So even if I tried to protect it with bubblewrap and such (which worked well in the basement), both the front and back ends of the handlebar were scraped up good when I started riding and it went flying on the pavement.
Today I went to a hardware store and got what I should have had from the beginning - plastic end caps to slide onto 22mm tubes. I also bought a large roll of gaffa tape (strong silver textile tape) which is A LOT more durable than the other kinds of tape I used to attach the bubble wrap.
If I had done what I did today from the beginning, the handlebar would have been unharmed. Then again, if I had not had the handlebar, the seat itself would have been completely banged up. Now the seat is untouched and the handlebar is fine except it will have to be used with those plastic caps from now on. I do also realize of course that even after I get proficient enough to ride safely, I might still UPD, or the uni could simply fall over while standing still, so the handlebar ends would have been banged up sooner or later anyway. In other words, I think I’ve found a good solution now.
I used the gaffa to rearrange and reattach the bubblewrap on top of the plastic caps as buffers - as before, but better positioned and covered in layers of protective gaffa tape.
The only drawback I see (which is potentially very bad) is that the bubble wrap and tape on the front part of the handlebar presents and obstacle to my inner thighs when I UPD forward. This could potentially cause my legs to get stuck in the uni and thus not allow me to land on my feet, which would mean a hard landing on hands and knees, with the uni seat and handlebar somehow mixed in there between my legs. Not a pleasant scenario.
But I’ve managed so far - usually I have to leap a little to the side and then I avoid the handlebar collision. I’ve had a couple of brushes though, that’s how I noticed. So just a little word of caution there to anybody as foolhardy as me, trying to learn to ride a uni on a coker, and not only that, but a coker with a T7 handlebar…
Mounting
Ok, let’s get to the interesting part. I worked out from 22 until about 2340, and I got video of all of it, more or less. I noticed from the very first mount that I had incredibly much more control today than even on Saturday. It felt natural to sit and I felt I could move the uni around, not being wobbly and so on anymore. Of course I had a few UPDs while just standing, leaning or riding slowly along the wall in the beginning, but I didn’t need to much time before I decided to just go for it and try riding.
Also, I am very pleased to notice that I seem to have found the secret of safe balls - pull the bike shorts way up and make sure nothing’s hanging around. When mounting I push the seat up firmly so I know it is well connected to my butt and there is nothing (guess what) in between, and then I kick off/step up. What I have also noticed is that when I am better at this, I won’t even have to do that, since I end up standing on my feet on the pedals once I have mounted, and then I settle down gently. Which means that the well-connected seat while mounting is not needed if the mount is successful - but it is crucial when I for some reason fail to get up and gain my balance. The hard part is of course to stay seated in that case. I’ve jumped up a little and then sat down hard on one ball in the process of UPDing, and that’s not pleasant. But none of that today - another big step forward!
Riding
So I managed to ride longer distances in general. I only failed 1-2 mounts after I got going, so I improved my percentage of successful mounts from Saturday, when it was already above 90% in the actual training period, after the warm-up (when I had lots of failed mounts). Today I didn’t really have many failed mounts during warm-up either
And I had several UPDs today after just half a revolution or less, but I managed to get a good run of 11 revolutions quite soon. And I had a bunch of shorter ones as well.
But I got so good today that I was almost contemplating not counting runs below 10 revolutions
What really amazed me was that I was suddenly able to ride fairly smoothly and straight, and not only that, but I was also able to slow down, turn a little and go where I wanted to go. Not always, and I would UPD a lot as well, or run into stuff (I started mounting in different places today, not just the same container wall as before - this was mostly due to needing a longer “runway” - so I also moved my car and my camera to get the “longitudinal view” instead of the “transverse view” of the parking lot and the container, so record my long runs for the first time (on Saturday you would just see me passing in front of the camera, or starting off and disappear).
I even managed to disappear today - as I actually rode around the far corner of the building
Before I got that far, I had 2-3 runs of 21 revolutions - so a new record from the 20 I managed in the last run on Saturday (when I UPDed big time). And then I had a string of runs between 10 and 20. I started mounting on the other side and ride back towards the camera as well (there was a truck there I could use as a wall) and finally I had one run of 24 revs, one a little bit later of 28 revs (there was one run of 9 revs in between). And then I thought I should call it a night since it would be better to quit while on top - but I know myself well enough to know that I would never quit while on the top if I think I can do even better. And so I did - I managed to get a whopping 30 revolutions on the last run!!! That’s a 50% increase from Saturday
So, here are the stats (I’ve copied the table from the previous post since I need to update the riding distances based on the confirmed 285 cm circumference of the wheel anyway).
RESULTS OF UNICYCLING SESSIONS
Day 1: Assisted mounting, balance training
3 hours inside. Distance covered: 0
Day 2: Assisted mounting, assisted riding
1,5 hours inside. Distance covered: 0
Day 3: Assisted mounting, assisted “free” riding
2 hours inside. Distance covered: “5 meters”
Day 4: Assisted mounting, riding, some freeriding
3 hours outside. Distance covered: 20-25 meters (record 3 revs - 8-9 meters)
My estimate is that I had 2-3 rides of about 3 revolutions.
Day 5: Assisted mounting, freeriding
3 hours outside. Distance covered: 260 meters (record 20 revs - 57 meters)
I had lots of rides below 5 revolutions, so I am not counting those anymore.
I had the following number of rides of 5 or more revolutions (after I started counting): 5, 4*6, 8, 9, 12, 13 and 20 - total 91 revolutions. That equals
Day 6: Assisted mounting consistently, freeriding reasonably balanced
I had the following rides of 5 or more revs: 25, 46, 8, 29, 210, 211, 12, 13, 216, 17, 3*21, 24, 28, 30 - total 353 revolutions of 285 cm each: 1006 meters total. Hey!
So I rode more than a kilometer today !!! In about 90 minutes !!!
Yes, you may congratulate me now
