does anybody know where i can get upgrade cranks and the crank bolts for a 20’’ torker unistar dx.
the only cranks that fit that hub i think are the quax ones from udc there about 50£ they fit on the yellow hub becuase that also has 8 splines why do you want to upgrade??
becuase i moved and my unicycle was apart an one of the arms got lost. i know its pretty retarted
ok so i found the other arm but i still need the crank bolts and pinch bolts do you guys know where i can find some thanks
Get this bolt:
http://www.unicycle.com/Shopping/shopexd.asp?id=927
You can grind the nubs off your cranks too if you want with these bolts.
thanks are u sure that will fit
Yes! I am totally positive.
