Norco, uni/changeable to MUni
Ok, here it is, i had a norco, well actually 2, a 20" and a 24". Ill start with the 20 " one first. The frame will hold together for awhile, if you land properly on soft ground, i weigh, i think 145 to 50 lbs, and i went off a i think 8 food drop on it, onto soft ground, held together. I think they come with 28 or 32 spokes (not totaly sure, mines 32 i think) im not sure how wide a tire you can fit on the 20" frame, i have a bmx tioga 2.1" tire, if i remember it has some room to go bigger. I eventually broke my 20" frame. (actually my friend broke it, well actualy both of them!
) they will brake were the bolts hold the frame to hte lolpop bearing holder, (the frame doesnt sit on the bearing holders, just bearly misses, on the 5 frames ive seen) I personally think that the seats, eather a Viscount, or another one that ive seen once, are very uncomfertable, i find that my ass slides down off the back of the seat. And the viscount front is to skinny. But some dont agree with this, and seem to ride them just find, i guess its just personaly preferance.
Now the 24" these ive seen 4 of, thats the one that ive been riding since last summer, till alittle while ago, you can fit up to a 2.6 " tire. i rode a kenda kolassal dh tire, it just fit, not sure if you couldd squeeze a 2.7 in but definatly not a 3". Again the problem was the seat, which i switched, and the frame were it cracks, at the base. As youve probably seen that the norco frame is not a flat crown, so you cant put your foot on it. You CAN put brakes on the norco, i my self have done it by taking a old bike forks, and cutting them in two places above and below the brake boses, about 1.5" above and belowe if you can. Then cutting that down teh back so you can bend it to the shape fo the fram, then attaching pipe clamps, around it and the frame to hold it in place, a cheap and easy way to attach breaks, the leaver part, i useed a diferent seat so my way of doin it would be differnt, you can see a picture of a brake mount on the gallery on this site, its one of a Coker, witha a blue Viscount seat. Another person ive talked to on icq also has attached brakes, im not totaly sure how he went around doin this, but i gues by welding them on.
The rim, i myself have a 28 spoke hub and rim on it, its not a stong rim, as its ment to be a road unicycle, my friends got 32 spoke hubs and rims, on thers, so i guess it changes wiht the unicycle what you get. I have just recently started to warp my rim, after breaking a spoke on it, after going off a small drop, ive been doing small drops on my unicycle for about 9 months i think. All about 3.5’ onto concreat. Depends on how you land, and how heavy you are though, my friends have warped their rims pretty bad. The crank arms, they to me have held up, im still using the same hub, axle, rim, ive just switched teh frame. My crank arms havnt warped or broken, although im sure they can. The hub, no idea about how good it is, proably best bet is that its not very strong. The norcos ive seen cost about 130 to 145$ i think, i forget. But thats al i got to say. About the Torker, im not sure how good that is, never rode it, but im sure that its a good uni. well hopefully i helped alittle. later.
