Today i actually looked at my torker Dx and i noticed that the seat doesnt point upwards and its just… flat
So my dad took it apart and turned the seat post around and now it looks perfect!
It’s kinda wierd because i never noticed it before, has this happened to anyone else?
PS. im not really sure if when i landed off a jump and it bent the seat…
ps.ps. I got a really bad peddle bite (or watever u call them) today
ps.ps.ps. ive always wanted to do a triple ps.
ps.ps.ps.ps. Do you think that when it was made they put it on backwards?
Depends on where your weight is. if you aren’t holding onto the handle with all your weight on it I’d venture to say its impossible breaking the stiffener plate at 2 feet. Don’t worry about it, just ride it as is.
dude, MAKE SURE THAT YOU ARE RIDING THE UNI WITH THE SEAT FACING THE RIGHT WAY!
ok, the reason its in all caps is that it unscrews your pedals if they are backwards… thats not good, it can easily ruin your cranks.just make sure the left crank is on the left and the right crank on the right, the frame doesn’t matter.
i was about to say somthing along those lines…more accurately, you should be riding with the crank arms on the right sides…just noticed, thats what you sayed in your explaination…
seatposts are too easy to break/bend… when i first started riding on a decent uni i bent a seatpost going off a 1 foot drop…
Yeah that is bad form. I went off 4ft and a couple 5’s I think with the seat post on my dx and I had decently bad form. I messed up a 5 set to break it along with my stiffener plate.
It is just landing smooth and rolling out basically if you land with all your weight going straight down into the uni it is going to put a lot more stress on it. The best thing for me was go find a set ( work your way up) and practice rolling out now that I am reasonably good at it I can backwards roll-out and stuff.
