I just got a used '07 Torker DX 24" and the bearings seem to be kinda tight unless I really don’t tighten down the cradle bolts much. They are barely past hand tight now, any more and it seems to really effect how easily the wheel turns. I’m concerned they may loosen up now. Any suggestions on adjustment?
The bearing cap bolts shouldn’t be very tight. You should use some sort of locking solution to keep them from loosening–either locknuts, Loctite, or lock washers.
The DX has locking nuts, the bolts on mine barely extend beyond the end of the nut. I find that provides sufficient tightness while not slowing down the wheel.
On my 24" DX I tighten the caps untill it effects the wheel’s turning and back it off a quarter turn, and check it over the next coulple of days. If I didn’t tighten it enough it will loosen and I can feel a slight wiggle in the wheel (but not while riding) I then increase the tightness by a quarter turn then it’s good.
