UDC says you cannot fit a Luna 20" Trials tire on the DX 20".
But Jagur has shown that a 3" Gazz Will fit on a Torker 24" which is supposed to be impossible. Does anyone know if the 2.5 x 20" tire will fit on the DX 20". I’m going to soon buy a low $ Trials and I would really like the strength of the DX. But more important I want a full size trials tire (2.5). So the Nimbus will be my choice if truly a 2.5 won’t fit the DX.
Re: Torker DX 20" Tire Size
Even if the Torker frame is wide enough to fit the Luna, it still wouldn’t work. The Luna tire fits on a 19 inch rim like the DX32 or Monty. The Torker comes with a 20 inch rim.
So perhaps I could use a 19" rim and spoke it to the torker hub?
You could, and it was something I was looking into for myself, the problem is that the Torker uses 48 spokes and most other rims use 32. Check this thread for more information:
http://www.unicyclist.com/forums/showthread.php?threadid=31997
Does anyone know if this tire will fit the Torker Frame? And is the stock rim wide enough for it?
Edit:
Have any of you tried the Maxxis Creepy Crawler? It’s available in 19x2.0 and 20x2.0.
I just put a Maxxis Max Daddy 20x2.25 on my Torker LX and it fits with about 1/4 inch to spare from the top.
Im also looking to get a dx 20" for trials.Most likly ill go down to a bikeshop completly unprepared looking for a trials tire to fit it.
cant you just get a tire that is wider but not specifically for trials?
thats what id like to know.
