torker bearing size
thinking of upgrading my muni crank/hub before i hit moab over thanksgiving, and i want a splined setup but can’t afford profiles. I also need 40 mm which means the KH/onza and Koxx hubs are out. are the torker bearings 40mm? would they fit the space left by a suzue hub? any other splined setups i’m forgetting and thereby not concidering?
A torker DX bearing is 20mm ID 40mm OD Part # is 132294.
You can get it from your LBS, they get it from Seattle Bike Supply.
I think you can actually get a KH/Onza and use Torker DX bearings to get it to fit into your frame.
neat. thanks guys.
