Tire/rim
WILL THIS RIM AND TIRE GO FIT TOGETHER?
http://www.unicycle.com/shopping/shopexd.asp?id=750
AND
http://www.unicycle.com/shopping/shopexd.asp?id=536
OR
http://www.unicycle.com/shopping/shopexd.asp?id=877
yes
the tire will fit to both rims for sure?
assuming you pick the 19" model of the DX32 yes
so the nimbus trials rim wont??
both rims will work. as long as you are using a 19" rim it will work with that tire.
I guess what I should have said was: “unless you choose a 24” DX32 rim"
the dx32 recommends with 2.6-3 and the cc is 2.5. I think it will work out though.
Getting off topic here but that recommendation of 2.6-3" tires on a DX32 rim is a bit optimistic.
Wide tires need wide rims and vice versa. I would put the range more around 2.3-2.6 as the DX32 has a 32mm inner width as the name suggests (wide for a bike rim but not that wide for a uni rim)
I used 3" tires on the 24 and 26" versions of the DX32 and felt the rim was to narrow for the tire.
