tire question
hi,
I dont know how wide of a tire my norco 24" rim/frame can hold. .
Currently i have a 2.0 on the uni and i was thinking of getting a 2.3 but i dont know what it will hold…any ideas.
thx alot, justin
Re: tire question
A 2.3 should fit, as I have a 2.5 on my 20" norco frame. Just take a look and
guess.
Dylan
problem
the problem is that i have to order the tire so if it doesnt fit im screwed
Re: tire question
I do not know about your frame, but as far as the rim/tire combination goes, you can figure out the range of matching tire sizes by referring to the following table:
It’s in German and uses metric sizes [mm], but translation/conversion is straightforward:
Maulweite der Felge = bead width
Reifenbreite = tire width
25.4mm = 1’’
X = good match
small bomb symbol = dangerous
other symbol = increased risk of getting pinch flats
Even more information and a similar table can be found at
This does not answer you question specifically, but I hope it still helps.
Have fun,
Fred
