Tire pressure
I’ve had my uni for almost 3 weeks now and I just discovered that the tire was a
little low on my 20" wheel. I weigh 170. I looked down and it looked a little
bulged out on the bottom. I checked the tire pressure and it was 27 psi. So I
looked on the tire and it said to inflate from 35 - 50 psi. Being as the high
pressure hose fills a little tire quickly I just popped on the tire chuck for a
second at a time and first time I got 35 psi, so I did it again and I got 42
psi. I left it there.
Then I went for a trip down the hall again and I have much more control. Does
anyone have any knowledge or thoughts on tire pressure and control?
     Lowell yoda@socket.net
Re: Tire pressure
Most unicyclist do overinflate their tire. Keep in mind that tires are not
designed for all the weight to be on one tire. Most tires work 50%
overinflated. Experiment till you find what pressure works well for you. The
exception would be a fat offroad tire. Be careful with high pressure hoses.
Hand pumps are best. -Mark
— “yoda” <yoda@socket.net>
> wrote: I’ve had my uni for almost 3 weeks now and I just discovered that the
> tire was a little low on my 20" wheel. I weigh 170. I looked down and it
> looked a little bulged out on the bottom. I checked the tire pressure and it
> was 27 psi. So I looked on the tire and it said to inflate from 35 - 50 psi.
> Being as the high pressure hose fills a little tire quickly I just popped on
> the tire chuck for a second at a time and first time I got 35 psi, so I did it
> again and I got 42 psi. I left it there.
Free e-Mail and Webspace - http://Unicyclist.com
Re: Tire pressure
On my 20" I usuly have the tire between 80 and 100 psi. I haven’t had any
problems with blowouts, but I always make shure that the tire is seated well. It
makes it easer to do trick and to turn on gym floors and stuff. I think it goes
a little faster too. I’m about the same weight as you; lighter people need less
pressue to get a good ride
Peter
>a little low on my 20" wheel. I weigh 170. I looked down and it looked a little
quickly
>I just popped on the tire chuck for a second at a time and first time I got 35
>psi, so I did it again and I got 42 psi. I left it there.
RE: Tire pressure
Never thought about the one wheel carrying all the weight but I guess it’s
really not a special tire. Good thought. Do you think the 42 psi I have now is
enough? I think I’ll get a hand pump, going to service station is a Pain anyway.
> _____________________________________________________________
Re: Tire pressure
I wish there were Presta valves for standard unicycle tires like my road bike.
They are a little more trouble but really hold up under high pressure. With my
250 lbs, I frequently overinflate the unicycle tires. Usually around 100psi.
Here’s a link to some Presta valve basics:
http://my.voyager.net/~olderr/bcwebsite/text/t/tirev.htm
Brian Berlin
Mark Stephens <Cokerhead@unicyclist.com> wrote in message
news:20000910190622.D19B5E0B5@sitemail.everyone.net
not designed for all the weight to be on one tire. Most tires work 50%
> Be careful with high pressure hoses. Hand pumps are best. -Mark
inflate
> >from 35 - 50 psi. Being as the high pressure hose fills a little tire
quickly
> >35 psi, so I did it again and I got 42 psi. I left it there.
RE: Tire pressure
> It makes it easer to do trick and to turn on gym floors and stuff. I think it
> goes a little faster too. I’m about the same weight as you; lighter people
> need less pressue to get a good ride
> Peter
OK, that makes 2 people that say more tire pressure. Sounds like I better pump
it up some more. Thanks for your input. I’m trying to learn all I can about
unicycling.
> >was a little low on my 20" wheel. I weigh 170. I looked down and it looked a
> >little bulged out on the bottom. I checked the tire pressure and it was 27
> >psi. So I looked on the tire and it said to inflate from 35 - 50 psi. Being
> quickly
Re: Tire pressure
could someone tell me how to get off this list?
----- Original Message ----- From: Peter Nyflot <peter-nyflot@bethel.edu> To:
Unicycle Mailing List <unicycling@winternet.com> Sent: Monday, September 11,
2000 2:13 AM Subject: Re: Tire pressure
> Peter
inflate
> quickly
Re: Tire pressure
For our normal street Miyata unicycles, the recommended pressure is 72psi, and
we’ve found that to work fine. When they get down to 50 or whatever, I pump up
to 80. That’s for 20" and 24" with normal (skinny) tires.
—Nathan
“yoda” <yoda@socket.net> wrote in message
news:000001c01b57$26c62b40$c72f6ad8@k4cybertech.mocty.com
> psi. So I looked on the tire and it said to inflate from 35 - 50 psi. Being as
quickly
RE: Tire pressure
> —Nathan
Sounds like everyone is using HIGH pressure. Makes sense with all that weight on
one tire. To make it clear as to what tire I have, it’s a Chene Shin Tire, 20 x
1.75 made in Taiwan, Nylon, inflate to 35 - 50 psi. I should have put all that
in my original message.
> quickly
> > Does anyone have any knowledge or thoughts on tire pressure and control?
