how do you freemount a three-wheeler? is it much harder than a 5-foot giraffe uni?
i’m asking cos i’m thinking of buying either a giraffe or a 3-wheeler … attracted to the latter (mainly for the sheer novelty) but not sure if it’s worth the extra expense and difficulty of mounting/transportation …
oh yes, another question, for those who own a Semcycle 3-wheeler: does it take long to assemble/dissasemble? (i’m presuming that it can switch to becoming a regular 1-wheeler too?)
I met someone with a three w and it was 6ft. Free mounting was extremely
difficult. Although i cant free mount a 6 but can a 5ft.
Dissasabling? I wouldnt bother if i was you!
RedTC “julianlim” <forum.member@unicyclist.com> wrote in message news:9hedbf$25i$1@laurel.tc.umn.edu… > how do you freemount a three-wheeler? is it much harder than a 5-foot > giraffe uni? > > i’m asking cos i’m thinking of buying either a giraffe or a 3-wheeler > … attracted to the latter (mainly for the sheer novelty) but not sure > if it’s worth the extra expense and difficulty of > mounting/transportation … > > oh yes, another question: does it take long to assemble/dissasemble? > > julian > > > > > – > Posted via the Unicyclist Community - http://unicyclist.com/forums
Of course it depends how big it is (how big the wheels are). If they’re
16" wheels, you can probably just step on the low pedal. If it’s 24"
wheels it will take practice, and a step between the wheels to boost you
up where you can get on the low pedal. If you have real good traction
between the wheels, you can do a running mount! But if you have that much
traction, riding the thing will probably feel like riding an exercise bike
with the friction turned way up…
>i’m asking cos i’m thinking of buying either a giraffe or a 3-wheeler … >attracted to the latter (mainly for the sheer novelty) but not sure
Not trying to talk you off it, but be aware that 3-wheelers have a
potential problem with (sufficient) friction, and with proper wheel
alignment.
Klaas Bil
“To trigger/fool/saturate/overload Echelon, the following has been picked
automagically from a database:” “FBI, Bagdad, Zyklon B”
thanks for the info, guys.
but what exactly do you mean by “problems with friction … wheel alignment”? … is this going to be a big worry?
also, i take it from the previous posts that mounting a 3-wheeler is essentially the same as a giraffe of similar height? or is there a slight difference in technique?
>thanks for the info, guys. but what exactly do you mean by "problems with >friction … wheel alignment"? … is this going to be a big worry?
Both these problems were stipulated in this newsgroup a couple of
weeks ago.
A problem with friction would typically be that the tires of either wheel
pair exhibit slip. That would quickly impair the control you have, since
your “commands” given to the pedals are not properly transmitted to the
bottom wheel and from there to the ground. If this happens try if
increasing tyre pressure helps.
The other thing is if the wheels are not aligned to rotate in the same
plane. Again the main problem is loss of traction and control as the
wheels tend to roll off each other. If you can’t adjust alignment there
may not much you can do about it.
In these respects a giraffe is just more tolerant, which may be a reason
that you see them more than 3-wheelers.
Klaas Bil
automagically from a database:” “cocaine, Scud, jihad”
