On my new muni (Koxx frame + 26" Alex D32 rim) I have mounted a light (850 g) WTB Timberwolf 2.7 foldable tyre. When riding it on low pressure it is very heavy to make turns. When inflated so the tyre is hard I can steer all right but at the slightest obstacle the muni bounces me off.
Have I bought the wrong tyre? Would a tyre with thicker walls be easier to steer at low pressure? Or is it a matter of practice?
When riding bumpy terrain, think “rolling bounce.”
I am using a 2.3 tire with medium pressure (enough to keep the rim from bottoming out). The tire is springy and would bounce me into the air. I learned to “roll” landings and continue pedalling quickly after hitting bumps. I spend more time “airborne” now but it is fun. Ultimately, with some timing, I would rather have the thin tire (than a Gazz) in a race.
It is harder to steer with a fat tire and/or low pressure, more rubber to the ground, making more friction for you to overcome.
THe good thing about it is that due to the larger (and softer) air chamber, it absorbs bumps with more ease.
Anyway, i go 4.5 bar om my studded 1.75 nokian xtrack tyre, and i’m all right! It just takes practice!
My initial thought was that the thin, soft side walls of the foldable tyre made turning tough and ineffective when riding with low pressure.
I guess more training will help keeping me in the saddle but riding a tight figure-eight on soft soil for two hours - that would kill me. I certainly need to improve my rolling hops and the rolling bounce concept was new to me.
Then do it in pieces. The point is to practice turning (tightly) in both directions. You will get better at it quickly - and be able to notice the difference along the way.
I learned about the rolling bounce “the hard way.” I was riding down a difficult hill that everyone takes slowly - and no one ever fell badly (only lots of UPDs). I came off a 1´ ledge, and landed on packed dirt - no problem. Then immediately, the tire sprang up with what seemed like more energy than I put into the tire. I was airborne. I did not even really try to catch myself because I couldnt believe I was falling - no one had fallen before. I ended up with several scabs (shoulder, wrist, both knees, ego)- and I still have traces of them. That day, I learned to pedal quickly from that bounce and it is a lot of fun. It is similiar to being able to continue pedaling when the wheel slips a 1/4 rotation.
Thinner side walls will make it a little harder to turn with low pressure. It feels like the unicycle is heavier then normal and is riding through thick mud. With thinner side walls you kinda need more pressure to keep the maneuverability but because it does have thinner side walls you can keep much the same bounce with more pressure.
