Hey, I was wondering if anyone was able to demo the Telford Muni while at the
NUC last week. And if so, what did ya think???
s-
s-
Re: Telford @ NUC
–WebTV-Mail-266125756-2616 Content-Type: Text/Plain; Charset=US-ASCII
Content-Transfer-Encoding: 7Bit
Steve, while at the NUC I rode the Telford in two configurations, 26" mountain
rim, and 24" narrow racing tire. I was very impressed with the unicycle both
times. It had only one draw back that I encountered. Being only 5’8" in stature,
and needing app: 32" between the bottom of the seat and the pedal at bottom dead
center, I found that I could not use the suspension seat post with the 26" Muni
rim and 7" crank combo that Geoffrey had set up. He had also made a (regular)
seat post which worked just great. With the 26" rim it was very agile,
responsive, quick, and most importantly to me a very smooth ride even with the
(regular) post. The angle of the seat post and flexable stays have elimated that
(jack hammer up the butt) action that we’re all too familier with! With the 24"
rim and shorter crank combo, I was able to use the suspension post and again was
impressed. Apparently, Geoffrey dropped it off a cliff on one of his Muni rides
and it took the beating. The construction was every bit as good as it looks in
the pictures. He uses very good components (if not the best) in all respects.
Viscount seat, aluminum seat post, Salsa post clamp, NK hub/stainless spokes,
etc. The suspension post has several different shims to tailor the ride to your
liking. I’m sure he will use anything of your choice, also. Can’t say enough
about the bearing holders. Much attention paid to every detail of constrution.
Top guality unicycle! Hope this helps in your analysis, Mike
–WebTV-Mail-266125756-2616 Content-Disposition: Inline Content-Type:
Message/RFC822 Content-Transfer-Encoding: 7Bit
Received: from mailsorter-102.bryant.webtv.net
(mailsorter-102.iap.bryant.webtv.net
[207.79.35.92]) by postoffice-132.iap.bryant.webtv.net
(8.8.5/po.gso.24Feb98) with ESMTP id HAA20259; Fri, 24 Jul
1998 07:38:17 -0700 (PDT) Received: from
icicle.winternet.com (icicle.winternet.com
[198.174.169.13]) by mailsorter-102.bryant.webtv.net
(8.8.5/ms.graham.14Aug97) with ESMTP id HAA05453; Fri, 24
Jul 1998 07:38:16 -0700 (PDT) Received: (from
server@localhost) by icicle.winternet.com (8.8.8/8.8.8) id
JAA19997 for unicycling-outgoing; Fri, 24 Jul 1998
09:28:43 -0500 (CDT) X-Authentication-Warning:
icicle.winternet.com: server set sender to
owner-unicycling using -f Received: (from adm@localhost)
by icicle.winternet.com (8.8.8/8.8.8) id JAA19803 for
<unicycling@winternet.com>; Fri, 24 Jul 1998 09:28:00
-0500 (CDT) Received: from milo.cfw.com(205.219.240.6) by
icicle.winternet.com via smap
(V2.) id xma019715; Fri, 24 Jul 98 09:27:31 -0500 Received: (qmail 28663
invoked from network); 24 Jul 1998 14:24:25 -0000 Received: from
c2s1m24.cfw.com (HELO gis-issi.com) (208.217.185.175) by
milo.cfw.com with SMTP; 24 Jul 1998 14:24:25 -0000 Message-ID:
<35B89984.A1C2AF00@gis-issi.com> Date: Fri, 24 Jul 1998 10:26:15
-0400 From: Stephen Bankston <bankstonSPAM@gis-issi.com>
Organization: Information Systems Support, Inc. X-Mailer: Mozilla
4.05 [en] (Win95; I) MIME-Version: 1.0 To:
“unicycling@winternet.com” <unicycling@winternet.com> Subject:
Telford @ NUC Content-Type: text/plain; charset=us-ascii
Content-Transfer-Encoding: 7bit Sender:
owner-unicycling@winternet.com Precedence: bulk Reply-To: Stephen
s-
–WebTV-Mail-266125756-2616–
