Hey guys! Here is my new video. Sorry for non-unicycling clips and poor quality. I had problems with Sony Vegas. Hopefully it’s not too boring
I have a few things to say
– I watched the whole video, which is a good thing, since I have a short attention span
– It was really nice to see trials out in nature!
Then also some tips video wise
– Sure I did not care for the flip stuff so much, but that’s your thing and your video, so no need to apologize for that.
– It would be nice to see some better angles, most of the shots were straight on. It would be cool to have you riding towards or away from camera once in a while, instead of just across the video frame.
– camera could be higher in some of those spots, low camera is to make tricks seem big, but I like higher camera for trials so I can see the obstacles they are riding on.
But you’re good, I can’t do that stuff yet I enjoyed the video, thank you for sharing!
Good vid,it felt a bit long:o It would have felt shorter if it was faster paced(faster hops, different camera angles, & some panning shots).
IMO those still stands should have been fast forwarded, like in Tom Pec’s Spirit (3:37-4:00) It’s nearly twice as long as yours, but doesn’t feel it because of the faster pacing, filming, and TP is amazing
Didn’t bother me either. I kind of liked seeing the different flips in different locations. But some feel that only uni stuff should be in a uni vid.
Nice video! Impressive still stands and flips!
Don’t apologize for the non-uni bits. I personally enjoy diverse videos. I also happen to be a juggler too so, I might be a bit biased.
BTW, your 5b looked clean. Could be a little higher, though. Just sayin.
Cool video. Thanks for making it. I enjoyed it.
Thank you guys!
I’m jealous of your flips…
By the way, if you ever need help with Vegas, let me know!
Thanks!
Sony Vegas doesn’t allow me to use Sony AVC format.
After it has been rendering ~90% it shows this error message:
I don’t know what should I do
This same problem happened to a friend of mine.
Try changing your project settings to a 32 bit pixel format, and try rendering again.
If this does not work, click “options” at the top and select “preferences”. Go to the “video” tab, and the second thing from the top should be “max number of rendering threads:”. Cut this number in half. Try rendering again.
Hope this helps…
