Super dumb question
Hi All,
It’s been three years since I was last on here intending to get a unicycle, three and a half years since I last rode one (managing 20 feet), and I still haven’t got one. I’ve taken a liking to the Nimbus Hatchet…opinions and suitability ?
Thanks :slight_smile:
There are no stupid questions.
Ahem.
Hatchets are cool looking unicycles that are made to fit extra wide tires. Extra wide tires are suitable for soft surfaces like sand, snow, dirt, and thick liquids. Or you can put in a not-so-fat tire and ride it however you want.
It’s definitely suitable for looking cool! I like them. But beyond that, it depends on the type of riding you want to do. If it’s just cruising around the neighborhood, don’t get a really knobby tire. :slight_smile:
If you only managed 20 feet like ever in your life, you should first stick to a 20" unicycle and learn to ride properly and then upgrade to bigger wheels. Learning on a smaller wheel is easier.
For a first unicycle, the Hatchet is overkill. It is big, with spiked pedals, and costs 600 pounds. It is an awfully nice unicycle to be getting dropped on the pavement over and over by a beginner, and it will use its spiked pedals to strike back at your shins in retaliation. It also has a high-quality disk brake that you will not be using for a long time, if ever.
Setonix’s advice is about right. Get a simple 20-inch, or even a fancy 20-inch if you want, and learn to ride it properly. You won’t fall as hard, and you will get better skills than someone who only rides around on a giant monster like the Hatchet. When I was doing my first rides of 10 meters or so, I was terrified of large wheels. Some beginners don’t have this fearfulness, and that’s fine, but you will also learn to ride better if you start with a 20.
Thanks
Thanks for the advice guys. Point taken about dropping a very nice unicycle on the pavement. Local neighbourhood is a death trap on the roads for cyclists, so I’ll be mainly off road - cycle tracks, waste ground etc. I did once have a standard practice unicycle, and managed to break it, so bomb proof is disireable !
IMHO, there needs to be something out-of-the-ordinary about your off-road terrain to warrant going wider that a 3" tire. Which is why the Hatchet seems to me like a niche unicycle. For a first unicycle, I agree with the others, above: Get a cheap 20". Good luck!
24?
I learned on an old 24 inch muni with 3" tyre.
Being just about on the tall side, at 1.85, I found the 24 inch fine to learn. I got myself a 20" a bit later, when I was able to do about 100m in one go, and found it much more ‘nervous’.
The big muni tyre, at very low pressure was great, I thought, because added some inertia to the ride that I think suited my slow and developing reactions.
There isn’t anything spectacular about the off road tracks where I live so comments regarding a three inch tyre are well received and understood. I have trawled the threads on this forum for info and have found some people learning on 24/26 inch. Advice ?
Also, while I’m here, if I am going to get a Muni, the ever popular questions of 24 or 26 inch and Nimbus or Qu-ax ?
Thanks again guys.:slight_smile:
I agree with you that the first time I managed to do 100m was when the tire was nearly empty, so it wasn’t so ‘nervous’ as you describe it. More friction makes it easier to balance, though my first uni I learn on was a 20". I also understand that going from bigger to smaller isn’t always easier as the smaller wheel listens more closely. Then again, that is also why it is recommended to learn on a smaller wheel. When ur good at the small wheel you have time enough to adjust on a bigger wheel.
I learned on a 19” last year, but as soon as I was able to ride around the block, I bought a 26” which I found much easier to ride (once mounted). I go back to the smaller wheel regularly to work on skills, and usually find that my 26” riding improves considerably even after short time on the smaller wheel.
You will definitely beat up your first unicycle, so a cheap one is fine for learning. My 26” came with a disc brake that I am not skilled enough to use and have little need for in Florida. I took the brake off last weekend and found the 1.25 lb reduction in weight made my uni more responsive.
Just choose one and get to learnin’! You will be so glad you did. There is nothing like unicycling.
I think this is really good advice for beginners. I am applying a similar logic to learning wheel-walking. I do it on the grass, where it takes more deliberate action to move the wheel and the wheel is less likely to slip out in front of me. Since WWing is a newer skill, my reactions are also slow and developing, and I’m not quite ready for the twitchiness of a smooth surface. (The chances of a bad fall are exponentially worse on pavement, as well.)
Learn on a cheap lighter one, if you quit, you lost nothing. A new learner on a hatchet would destroy the hatchet frame. And your wallet.
Thanks for all the advice guys. I won’t be wrecking a nice Hatchet until I can ride fairly well. I do like that idea of learning on grass with a Muni tyre !! Grass is inherently softer than pavement !! :slight_smile:
Yup, like everyone is advising, get a 20” to learn on. I learned on a 26” muni, it took me a lot longer than it would have if I had chosen a 20”. I did buy a 19” later on and it is definitely easier to learn things on, and then it was
quick to transfer that skill to the 26”.
Careful that grass is also uneven and its softer nature means it is a lot harder to pedal through (the smaller the wheel, the harder).
However, any area with packed dirt will be way easier to ride while dirt is still softer to fall on than concrete :wink:
I also am not a fan of riding on grass, the biggest problem for me is it hides the actual ground so you can’t see the bumps. It is especially bad on a small wheel. There is no sense in making learning harder. The best surface for learning is smooth with no bumps. Usually ends up being pavement or a gym floor. I wouldn’t let the fear of falling dictate where you ride, if you can ride 20 feet you are well into the learning curve, just keep on riding.
If a beginner can ride 20 feet, then I agree, they are probably better off sticking to a smooth surface, like you said. If a beginner aspires to muni, they need to 1. eventually get comfortable riding with one hand on the seat handle, then 2. Start riding on uneven surfaces.
I agree that “there is no sense in making learning harder.” But that philosophy can be misinterpreted in a variety ways. Just because we are struggling, that doesn’t mean we aren’t learning. And, perfecting our current technique, with all its limitations, doesn’t necessarily move us toward the next technique. Bottom line: Newbies should experiment, they should try a bunch of different things.
I almost got a hatchet two years ago.
Such a cool looking machine, right? It can go from 26 to 29 wheel with same frame? 4" tires to go from sand and snow? Also, I saw a video of someone riding it straight up a street curb…yes, up a street curb!! I want that!!, but at close to $1000…I was a little hesistant.
If I had just waited 2 months before buying my 24" Nimbus Mtn, I would have seen the hatchet on sale for $500 on amazon!!! I would have definitely bought it at that price. (why so cheap, it was probably somebody returning it)
Anyways, fast/frwd to now. I hardly see anything about the hatchet. No new videos. It’s barely selling. I hear rumors that it’s a bit awkward to ride and the idea that it can handle 26.5, 28, 29 tire size…well that means you have to spend a lot of money for the rims/tube/tires…fat tires ain’t cheap.
My enthusiasm for it has waned a bit, and I’m having good progress on my 24". (maybe more than, if I had actually been able to get the hatchet…perhaps my progress would have retarded a bit with that machine) So, I still want to ride a hatchet, but I will just wait until I find another unicycle rider who might owns a hatchet and give it a try.
I encourage beginners to only make initial attempts on grass mainly because the first thing they should learn is the “emergency dismount”. Falling is a constant companion of the unicyclist so best get to know it early. Build the falling skill as you build your riding skill. Fear is a serious learning inhibitor.
For the same reason always wear protection, especially wrist guards.
Very few new riders can get anywhere on the first attempt so it doesn’t matter about grass being harder to ride on. Of course, best if it fits the description of “lawn” rather than “paddock”. I learnt on rough grass and it definitely made it very frustrating but I was quickly able to learn to deal with terrain when I got out onto the roads and footpaths.
The grass does reduce the tendency of the uni to fly out from under the rider giving a little more time to react.
A slight downhill overcomes the grass resistance to pedalling.
However once you can manage a turn or two, best move to a hard smooth surface and it will seem really easy.
Don’t underestimate the skill involved in doing that, even on a very fat tyre.
