I just found this unicycle on amazon for $104. Can’t tell if it would
work for trials riding. I’m wondering if it’s crap because
it’s only 104 dollars, and most trials uni’s are a LOT more than that
what do you experienced unicyclists think about this uni?
That rim/tire looks way too heavy for trials and its got a cotterless hub and cranks which won’t stand up to much abuse. I strongly advise against using this for trials. You would probably be better off doing trials on a freestyle unicycle than that thing.
the rim and tire were made for the 1st gen walmart “schwinn stingray” chopper bike, and they’re more of a novelty item. the tires are fairly slippery, and i’m pretty sure you can’t find a much softer alloy single-walled rim.
If you were going to learn to ride at the beach. Or anywhere with soft ground. It would be fun to ride, and better in some ways, but I would guess heavier and harder to turn.
I’ve never ridden one. I wish I had a 24 with a 5 " tire to ride at the beach.
I agree it is mostly a novelty, on hard ground. The huge tire might take a lot of abuse, allowing big drops. But as a 100 $ Sun, unless you are real light, maybe the crank will snap off.
