Sun FT 20 Specs
I damaged the hub on my Sun FT 20. To replace it, I ordered the “Unicycle.com 36 - hole Wide Chromoly Hub” http://www.unicycle.com/unicycle-hardware/hubs-and-hub-assemblies/unicycle-com-36-hole-wide-chromoly-hub.html taking their word for it when they say “Will fit most unicycles”. But of course it doesn’t fit. The bearings are too far apart for the frame.
Does anyone know the specs for this unicycle? I don’t know what hub to buy.
You should probably ring UDC, although if you want to do anything more than just ride around i’d say a new unicycle was in order. :slight_smile:
