sturdier uni tires?
This request is probably a bit odd. Please forgive a newcomer to this forum.
I have had my Schwinn uni for almost 15 years. It’s kept its weight about
the same, but I have gained a few pounds over the years (o.k., maybe more
than a few).
I am afraid to idle for any length of time for fear that my tire will go flat.
When I idle, the bottom portion of the wheel compresses to next to nothing.
Is there a studier tire brand I can replace my original tire with (whoops, I
meant “sturdier” up above)? Or, can I replace it perhaps with some sort of solid
tire instead?
Thanks for your help… Russ K.
Russ Kaufman “The Quintessential Hobbyist” rkaufman@cap.gwu.edu
Re: sturdier uni tires?
In message <199412310259.VAA26849@cap1.CapAccess.org> Russell Kaufman writes:
> It’s kept its weight about the same, but I have gained a few pounds over the
> years (o.k., maybe more than a few). I am afraid to idle for any length of
> time for fear that my tire will go flat. When I idle, the bottom portion of
Is it fully pumped up? You never know with these things… It’s my impression
that a unicycle tire should be slightly fuller than a bicycle tire…
| jimmy@juggler.demon.co.uk | PGP v2.62 Public Key Available on
| Request |
