Ok first off I’ll start with my frame. I was just rding and I was looking and my frame is not level on my wheel. I looked and found out that my wheel was in true so what should I do to fix it.
Ok next I have some questions on grinding and stuff.
I have a grind rail but is there something else that would be better to grind on?
2.Is it possible to grind with the pins in my pedals and with out a grind plate? I am going to leave my grind plate on there for now but when I start getting better at trials I want to get rid of it but still grind.
I think that is everything and if not I’ll just ask or something
What…
thats not going to fix anything.
take the frame off, add shims/take shims off make it even again. add the shims to the side that is farther from the tire.
you can make some if you don’t have them already. thin rubber works well, or plastic bags if you need to use it.
if those aren’t an option, cutting up a soda can to fit should work.
I thought about shims but I wasn’t quit sure. I have been riding this frame since christmas and ever since I had noticed that it felt crocked but I didn’t think anything about it until today. Also i might make them into to seperate topics after i get done with my home work
Whatever you do, don’t do this. Then the frame with be backwards, therefor the cranks will be on the wrong sides, therefor your pedals will unscrew themeselves, therefor your cranks will strip, therefor you will need new cranks and new pedals.
If you do that you have to turn the frame AND the seat around. That is a test to see in the frame is actuallt bent, and it will tell you which side to put the shims on, the side that is FARTHER from the tire. I would probably use soda cans for the shims, whatever works though.
did you not read that he said to first turn the frame, then the seat…i dont understand why you mob are bitchin about his post??? made sense to me, read it properly.
