Re: Stopping a 28" uni
Text item:
Stephen Gun <guns@camtech.net.au> wrote:
>I’ve just bought a DM 28" for commuting. The speed is terrific, but I am having
>trouble stopping within a reasonable distance (without dismounting). Can anyone
>give any suggestions on stopping techniques? Is it practical to use brakes
>without slamming your face into the road?
I don’t recommend brakes because the hassle of setting them up and the amount of
practice required to successfully make an emergency stop will probably not give
you satisfying results. As the wheel gets bigger and the crank arms get shorter,
a unicycle will have more momentum and require more effort to stop. you could
use longer crank arms to increase your leverage, but they would also decrease
your speed.
Here’s what I do: On my 45" big wheel (6.5" cranks) if I have to make a panic
stop, I know I can’t come to a quick stop in a straight line. So if there’s a
place to do it, I make a quick 90 degree turn to the side and really dig in the
tire. This can give you a much quicker stop, as long as you have room to do it.
>I highly recommend a large wheel to anyone. Having ridden distances up to 10km
>on a 20" uni, the 28" one is so much more relaxing, it rides over bumps better,
>and pedalling it doesn’t seem futile. Another problem I’m having, though, is
>it’s become really hard to ride the old 20" uni!
Save the 20" for freestyle, teaching people to ride, and letting your friends
use when they’re visiting from out of town.
John Foss reply to: unifoss@calweb.com http://www.calweb.com/~unifoss/
Text item: External Message Header
The following mail header is for administrative use and may be ignored unless
there are problems.
IF THERE ARE PROBLEMS SAVE THESE HEADERS.
Reply-To: “Stephen Gun” <guns@camtech.net.au> Precedence: bulk Sender:
owner-unicycling@winternet.com Xref: paladin.american.edu
rec.sport.unicycling:4800 Path:
auvm!paladin.american.edu!zombie.ncsc.mil!newsgate.duke.edu!
solaris.cc.vt.edu!newsrelay.netins.net!mr.net!newspeer.monmouth.com!news.monmo
uth.com!uunet!in5.uu.net!ozemail!news.mel.aone.net.au!newsfeed-in.aone.net.au!n
ews.mel.connect.com.au!news.ade.connect.com.au!duster.adelaide.on.net!news.camt
ech.net.au!di Lines: 12 Date: 18 Dec 97 06:42:25 GMT NNTP-Posting-Host:
dialup-ad-14-53.camtech.net.au X-Newsreader: Microsoft Internet News 4.70.1155
Message-ID: <01bd0b81$2254a020$b4f237cb@a002540.banksa.com.au> Organization:
Bank SA Newsgroups: rec.sport.unicycling Subject: Stopping a 28" uni From:
“Stephen Gun” <guns@camtech.net.au> To: UNICYCLING@winternet.com Received: from
AUVM.AMERICAN.EDU (NJE origin NETNEWS@AUVM) by AUVM.AMERICAN.EDU (LMail
V1.2a/1.8a) with BSMTP id 7880; Sat, 20 Dec 1997 15:16:27 -0500 Received: from
AUVM.AMERICAN.EDU by AUVM.AMERICAN.EDU (IBM VM SMTP V2R2) with BSMTP id 3633;
Sat, 20 Dec 97 15:16:31 EST Received: from auvm.american.edu(147.9.1.2) by
icicle.winternet.com via smap (V2 .0) id xma024719; Sat, 20 Dec 97 14:19:33
-0600 Received: (from adm@localhost) by icicle.winternet.com (8.8.8/8.8.8) id
OAA24996 for <UNICYCLING@WINTERNET.COM>; Sat, 20 Dec 1997 14:20:49 -0600 (CST)
X-Authentication-Warning: icicle.winternet.com: server set sender to
owner-unicy cling using -f Received: (from server@localhost) by
icicle.winternet.com (8.8.8/8.8.8) id OAA25076 for unicycling-outgoing; Sat, 20
Dec 1997 14:21:26 -0600 (CST) Received: from icicle.winternet.com
(icicle.winternet.com [198.174.169.13]) by thalia.fm.intel.com (8.8.6/8.8.5)
with ESMTP id MAA09489 for <JohnX_Foss@ccm.fm.intel.com>; Sat, 20 Dec 1997
12:57:02 -0800 (PST) Received: from thalia.fm.intel.com (thalia.fm.intel.com
[132.233.247.11]) by fmm ail.fm.intel.com (8.8.5/8.7.3) with ESMTP id MAA25360
for <JohnX_Foss@ccm.fm.int el.com>; Sat, 20 Dec 1997 12:55:44 -0800 (PST)
Return-Path: unicycling-owner@icicle.winternet.com
