hi
I got my uni today it is so much fun I think im doing quit well I can go very far on it:D . But how do you slow down/stop like for going down curbs and stuff or just for stoping?
just slow down your pedalling and it will slow dow. to stop just stop pedalling.
o ok lol. how do you get on with out holding on to anything?
i hold on to the front of the seat. Then have the pedals at the 8 and 2 oclock positions. put your strongest foot on the 8oclock position pedal put most of your weight on it, then step onto the 2oclock position and start pedalling. it might take a while to get used to. good luck
is it the 8 oclock on th front or the back .
thanks
8 is the pedal closest to you. good luck learning.
And welcome to the forums.
thanks a lot
merry christmas to all
He meant to say 5 o clock not 8. Put your foot on the closest, bottom pedal, in a 4/5 o clock position.
no i find it easier to have it at 8oclock, but the more common method is 5oclock position
I suppose I got confused over which side you look at 8 o clock on. Do you mean you put your foot on the pedal at the bottom and your side of the axle?
If you don’t… I think that’s rather unorthodox.
Is that 8 O’Clock Mountain Standard Time or Central?
What if my Unicycle is Digital?
so confused…
