Stealth Impulse Rim vs Stealth Pro rim
Has anyone upgraded from the Nightrider Pro rim to the new Stealth Impulse 36" rim? From UDC, it seems that the stealth impulse rim saves .2 pounds with the holes, has anyone done some weighing of actual rims to see if in fact the weight is correct at 2.2 lbs vs the 2.4 lbs that the non-impulse rim?
I’m wondering if it is worth upgrading before I rebuild my geared 36er for the winter.
Just drill your old rim yourself. It isn’t hard and you can decide how big or small to go, one wall or two, etc.
