Stationary Unicycle?
Anyone here ever setup a unicycle on rollers? I can’t be bothered to ride in temperatures less than 40F.
Yeah I have not yet but I’m quite interested. It has been discussed briefly here in the past, and yes people have tried.
Since rollers keep you in one spot you would likely need to hold onto something to stop yourself from falling forward/back. Also if the unicycle turns it will drop the tire between the rollers and make you fall.
Still I want to try it, I miss my 36 in the winter, and I always get out of shape. It would take up much less storage than a workout stationary bike.
I took my 36er on a treadmill briefly - just long enough to get some video. Wouldn’t recommend it.
I would think this would be a really bad idea. Basically that’s like doing a stillstand, but with pedaling, it sounds extremely difficult to me. All your normal balance is from being able to move the unicycle around underneath you, not you moving your body around the unicycle.
Yeah I don’t think it would be very possible without holding onto something stable, like a chair or railing.
I’m not interested in balancing on the rollers, just getting a quick indoor workout on my 36.
Oh ok well then possibly with some bars to hold onto, but it still sounds sketchy to me, especially on a 36.
This has come up a few times on here. Treadmills have been mentioned…I have to wonder though what the intention is.
Is the intention is to be a better rider? In what way?
I’m not sure that any sort of stationary practice would be realistic but am curious if others have any experience on that.
If the intention is to get exercise and develop strength why not just get an exercise bike?
Learn to idle and then you can develop strength and skill stationarily.
Treadmills and rollers can be so deceiving to some people. I’m sure this would apply to a unicycle as well, but running on a treadmill, and actual running, work out different muscles. With using a unicycle and holding on to a bar of some kind (Which I’m pretty sure you would HAVE to do) you wouldn’t workout all of your balancing muscles like in the stomach.
I think if you were able to succeed in riding a 36 indoors on rollers, the only benefit may be to burn some fat, in which case wouldn’t a normal exercise bike be better? just don’t use the handlebars! :slight_smile:
Most exercise bikes really only have one wheel if that makes anyone feel any better.
http://lmgtfy.com/?q=winter+jacket : P this better be a very elaborate joke. . .
According to the OP, the intention is to get out of the weather (and possibly darkness). On a unicycle. Anyone can get on an exercise bike, but then it’s a topic for a different forum.
I’ve never tried rollers, but it’s easy enough to picture the difficulties. No front-to-back balance correction, and a tendency for the wheel to wobble, which could lead to it falling between the rollers. No fun.
Treadmill ftw! This I have done a bit, and it works though one must use care. Also I imagine it might put wear & tear on the treadmill that it might not be built for? In the form of all the rider’s weight on a very small spot. But then again, maybe not such a problem, because you aren’t pounding your feet onto it. :slight_smile:
Okay, I should mention I ride in snow alot and have been at it for years. I would commute in snow if I had some good winter cycling clothing, but it’s not cheap. Riding in winter ski jackets you are either too cold or sweating, so rides over an hour aren’t as fun.
My hope was to exercise my legs (not burn fat). Every spring I feel like I need to get trained and back in shape to keep up with the other cyclists on the road:). I don’t want more balance practice. I would love to have an exercise bike, but they are big. I already have a bedroom full of unicycles.
I know there are people on the forums that have tried it before.
I think you’d be best to learn idling and forget the rollers. You wouldn’t want to spend your springtime in a body cast! :roll_eyes:
I can’t idle the 36 that well but i already can idle, thanks. I don’t think rollers could ever help me idle? I wasn’t planning buying them anyways.
If the unicycle was completely secured, I could see a benefit of conditioning to saddle and burning fat. I think that may be your best option if you want to persue this.
sooooo, what you’re saying is, it’s not a joke. . .
Well it was tried at Warwick races a few years ago - I can’t remember the wheels size probably 36". Although the person was extremely good at freestyle the rollers didn’t provide enough friction to maintain balance. The solution IIRC was someone resting their foot on the roller to increase the friction.
Even though I have the rollers and Uni’s it isn’t something I’m going to try anytime soon.
The only realistic solution would be to get some rollers which have a friction unit attached (to basically make it a combined roller / turbo trainer). Or just go out in the cold :smiley:
use an exercise bike - while sitting up straight
yea, I was wondering how in the world you would do it with rollers (not that it can’t be done, but it’s probably more trouble than it’s worth), and why you would really want to do it. It wouldn’t be much more than saddle conditioning and spin practice. I don’t think you would get much of a workout from it. . . and the scenery would suck : P
if you wanted inside practice, just idle on one side for 5 minutes, then idle on the other for 5. just keep switching sides. to make it harder you could keep lowering the seat little by little. You could even get some short (70mm) cranks.
I would just suck it up and brave the cold if it’s anywhere above 20 or 30 degrees. it makes for a more epic ride anyway : )
Just found this by accident:
http://www.youtube.com/watch?v=_CK25THcPMk
