spokes "ticking"
Hey there. I just bought a used KH24 (2010?) in great shape and am stoked. I’m a noob, so don’t know if this is weird or not… I took it out for a spin on a local bumpy soccer field to get used to the larger (than 20") wheel, and three or four times over half an hour, I heard a faint “ping” or “tick” come from the spokes (or one spoke). Everything is tight… so… wazzup? I didn’t hear it on my older KH20…
I wouldn’t worry about it unless it is a consistent thing. Wheels flex and the spokes move a bit. The noise is most likely a spoke seating itself. Usually new wheels will do this at first. Since the uni is new to you, it may be getting used to your weight.
post in Rec.Sport, not Just Conversation.
might be the bearing cups check to see if there tight
