spoke fitting questions
would koxx-one spokes fit on a KH moment hub/ rim?
thanks,
Miles
if they don’t, what size spokes do I need?
I don’t know any of those measurements :frowning:
is the data not on the UDC spoke calculator?
okay it is, thanks!
would 14 gauge spokes that are 2.8 mm shorter than what is says is ideal work?
edit: I’m planning on using the KH moment hub/ rim
2.8mm…
I’d lean on saying no.
Do this… see how much the spokes connect with the nipples THREADS.
Be careful though, some nipple threads are deeply set into the nipple… meaning the spoke can sometimes go into the nipple about 2-3mm before it even engages threads.
Also, if you don’t have the measurement, measure it, or look them up.
