Split frame? Fixed it!
Well, a few days back I was riding my 26" uni that I got off of unicycle.com (it was the one that was $66 because they were clearing them out or something) broke. I don’t know how it happened, but the part of the frame that attatches to the lollipops split up the middle of the forks for about 3 inches! Well, I really liked this uni, so I figured out a way to fix it. What I came up was as follows:
*Bend the bottom of the forks back into shape so it fits snugly over the lollipop.
*Next, cut a 3 inch piece of 1 inch tubing to go around the broken seam (angle it at the top)
*Tack weld the pipe to the frame in the front and back (providing they are both steel. If its steel and aluminium, its done. Steel and aluminium don’t weld together.)
*Drill out new holes in the pipe so you can bolt the frame to the wheel
*Put it a set of 8-point safety wire bolts in place of the old bolts
There was really no reason to use safety bolts, I just thought they looked cool!
Doing this to the 26 not only fixed it, but strengthened and stabilized the ride. It may not look super flashy, but its a very good ride compared to what it was. Just thought you guys might find it a cool fix.
same exact thing happened to me on my savage. I think i was jumping around too much, so the two bolts (same as the two seen in your picture) ripped right up through the frame. I, on the other hand, have no clue how to weld so i was unable to fix it. so, i sadly was forced to upgrade to a kh24 :stuck_out_tongue:
-grant
My frame has a crack in it that could be fixed by a little weld but then that doesnt fix the fact the frame is bent lol
Trev
Nice fix! That’s a typical problem with that setup.
I’ll second U-turn, Nice Fix! You’ve just added more miles to the uni… --chirokid–
