Re: someone has expierience with hammerite paintjob?
On Thu, 14 Sep 2006, UNIquelyCanadian <> wrote:
> bailingmarne wrote:
> > Has somone some expierience with frame paintjobs?
> > I’m gonna order a new costum uni and i was thinking about painting the
> > frame with Hammerite metal paint, grey and a smashed hammer effect
> > is there someone who did this before, does it go easy ?
> Consider it a very temporary paint job. I used “hammered” spray paint
> on my MUni and once it was badly chipped I had a local body shop redo
Hammerite is a very tough glass-flake enamel. I find it at least as
durable as powder coat, and it’s certainly much more tolerant of the
underlying surface - it will even cope with light rust remaining (as
long as you shift any loose material). If you have bad rust there’s a
specific undercoat which tolerates almost anything short of lumps
falling off.
It’s relatively easy to apply, but beware - it doesn’t like overcoats
outside the specified time limits - read the tin, and believe what it
says. Either you need to do a second coat fairly fast (soon after
touch dry), or you should leave it weeks.
It wants to go on a little thicker than most paint, and normally one
coat is sufficient. Obviously, you need to ensure it doesn’t go on so
thick it slumps.
You normally can see the joints between coats, so it’s best to arrange
supports so you do the entire job in one go, start painting at one
extremity and do a continuous coat all the way to another extremity,
avoiding putting wet paint alongside dry at any point. On a unicycle
frame, this probably means stripping it and hanging it from something
slotted through the seat-clamp bolt-hole.
It skins quite quick, so even like this you need to work quite fast to
avoid the visible joins, and it’s really annoying if you miss a spot -
when you try and go back and touch it up, it’s easy to make more of a
mess.
Best thing is work out exactly the sequence you’re going to paint,
then do it fast-but-thorough first time, one go, one coat.
Don’t try and bake it - I tried accelerating it in an oven once (only
very slightly warm) and it discoloured. Let it dry at ambient
temperature.
The genuine hammerite solvent makes brush cleaning much easier. Both
that and the paint are very fumey - make sure you have good
ventilation and don’t smoke / practice your fire-clubs / otherwise
play with naked flames at the same time.
In most cases I prefer the smooth to the hammered finish, and I’ve
only ever used smooth on bike or unicycle frames. Generally, it’s a
good, very durable, surface-tolerant, easier-than-most paint.
regards, Ian SMith
|\ /| no .sig
|o o|
