It has some scratches on the frame and a little tear on the seat as you can see in the picture below.
The seat post was cut a little short as for a short rider (inseam 29" - crotch to feet). I will also provide a large padded bag for transporting/shipping unicycle. I used the bag to transport the same to unicycle to five continents.
I am not sure exactly what I should look for. Here are the information from when I ordered it.
**Kris Holm 29" Unicycle**
***KH ISIS Moment Crank Option:***
125/150 Double Hole Crank (standard on cycle)
***KH Saddle Choice***
Freeride Blue (standard on cycle)
***Brake Option***
No Brake
***Hub Option:***
ISIS Hub (standard)
***KH Clamp Color Option:***
Black (standard)
By the way, it seems you are in CA. The unicycle is still available but also has someone who may pick it up locally in a few weeks. I would prefer local. Just FYI.
If it is the 2010 frame (and in the pic it seems like it), there is no disk tab just the magura mounts for rim brakes. You will need to get a D-Brake, get a tab welded or change the frame.
As for the hub, there is no KH disk hub because it goes on the Spirit cranks. So as long as you have an ISIS hub, you just need to get Spirit cranks.
You won’t find them in the first Wal-Mart you walk into but they are a lot of them used and technically they are still produced to this days (and I even saw some on new touring bikes sold in Germany !).
The real challenge would be with the choice of rims if you decide/need to replace the KH one of this uni. In the siamese wheels world, there are now a lot of disk brake rims that di not have the rim brake surface (or reinforcement).
And if you need/want to go for a disk brake setup and do not know a good welder, you can get a D-Brake adapter and you are good to go
Yes, the forum is partially self-maintained by the community and regular users get access to this kind of little tool (like editing other users’ topic titles).
@jeep4wd I think you should be able to edit the title though. Do you have the pencil icon next to the title right now?
