I have been riding for about three months I have a 26” Torker LX. here is a list of things I can do.
mount with left foot
mount with right foot
ride 10 meters between two parallel lines 30 cm apart
ride a figure eight with circle diameters smaller than 3 meters
ride down a more than 15 cm vertical drop
demonstrate 1 1/2 types of mounts
ride a figure eight with circle diameters smaller than 1.5 meters
come to a stop, pedal half a revolution backward and continue forward
ride with the stomach on the seat for 10 meters
make a 180 degree turn to the left within a 1 meter circle
make a 180 degree turn to the right within a 1 meter circle
hop more than 5 times
ride or hop over a 10 x 10 cm. obstacle
idle with left foot down 25 times
idle with right foot down 25 times
Yeah I agree, your doing fine. Really the only pace that is normal is the one that you can handle. Unicycling is wierd because some people learn in leaps and bounds for no apparent reason, while others will learn very slowly.
For me I find that I learn really slowly for a long time, then boom I will learn a whole bunch really fast, then its back to slowly creeping.
Alot of it has to do with motivation aswell. When I’m motivated to learn a trick and I practice alot and really hard, I will learn much faster, but if I’m just messing around trying to learn a few new things, it will usualy take me a long time.
I also find that I can pick up the basics of most freestyle moves pretty easily, but to be able to do them farther than one or two revs will take much longer. On the other side of that though, learning street tricks usualy takes me a long time.
Long story short, your doing great, don’t worry about a thing.
You’re doing better than me! I’ve been riding since November and can only just now right about 3 feet away from whatever I use to mount. And thats only like every 4 out of 10 tries! Ah well, thats what you get when you only ride for like 15 minutes every 3 weeks!
