Re: Silty/Sandy Muni (formerly Re: Muddy Muni)
--------------25AE4BC0EE7FFB5A6E6402B0 Content-Type: text/plain;
charset=us-ascii Content-Transfer-Encoding: 7bit
You probably want lots of knobbies and a fat wheel. Also, I know from regular
mountain biking that there is a technique to negotiating hills with gravel/sand
or anything that is prone to slip out from under your wheel. There is a tendency
to want to lean forward (and to stand up on a 2-wheel) to get the required power
to turn the pedals. However, this shifts your weight forward, and the wheel just
spins. You need to sit back as much as you can to get your body as close to
perpendicular to the trail as you can, and not put so much force into the
pedals. There is a critical point where the force you put in is just higher than
the maximum friction between the wheel and the ground, and putting more force in
will cause the wheel to spin uselessly. You want to get as close to this point
as possible without exceeding it. Takes a little trial and error, but you should
get it. Also, if the wheel does start to slip, let up on the pedaling a little
and it should catch again, after which you can continue up the hill. In my
opinion, the technique here will help a lot more than the tires.
Luke
I've got the exact opposite problem - an arid climate (SE Arizona) with a
fair bit of silt and sand. They're not everywhere; they just show up in
inconvenient uphill grades where you find yourself quickly spinning through
a revolution or two, then falling off. Granted, I'm not working with the
best skills or hardware, but I think there must be a solution either within
the tire type or my skill set. Does the fat wheel/tire axiom apply to silt
and sand as well as mud?
--------------25AE4BC0EE7FFB5A6E6402B0 Content-Type: text/html; charset=us-ascii
<!doctype html public “-//w3c//dtd html 4.0 transitional//en”> <html> You
tendency to want to lean forward (and to stand up on a 2-wheel) to get the
required power to turn the pedals. However, this shifts your weight
forward, and the wheel just spins. You need to sit back as much as you can
to get your body as close to perpendicular to the trail as you can, and not put
so much force into the pedals. There is a critical point where the force
you put in is just higher than the maximum friction between the wheel and the
ground, and putting more force in will cause the wheel to spin uselessly.
You want to get as close to this point as possible without exceeding it.
Takes a little trial and error, but you should get it. Also, if the wheel
does start to slip, let up on the pedaling a little and it should catch again,
after which you can continue up the hill. In my opinion, the technique
<p>Luke <br> <blockquote> <br>I’ve got the exact opposite problem -
an arid climate (SE Arizona) with <br>a fair bit of silt and sand.
They’re not everywhere; they just show up <br>in inconvenient uphill grades
where you find yourself quickly spinning <br>through a revolution or two,
then falling off. Granted, I’m not working <br>with the best skills or
hardware, but I think there must be a solution <br>either within the tire
type or my skill set. Does the fat wheel/tire <br>axiom apply to silt
and sand as well as mud?</blockquote> </html>
--------------25AE4BC0EE7FFB5A6E6402B0–
