Shin Guards
Hi!
Maybe a bad way for introducing oneself to the forum, but I’ve got to ask the stupid question :wink:
Can anybody tell me, what’s the difference between soccer shin guards and the special bicycling shin guards? I know, the one are meant for bicycling, the others for playin soccer. But why? Is there a reason against using soccer shin guards for unicycling trials? (or a reason FOR bicycling guards)
I have neither of them, but I just recognized, soccer shin guards are way cheaper (: …
thanks alot,
jabbath
these are good shinguards for BiccLig/unicycling:
These are soccer shinguards:
You can see that shinguards designed for Biking covers a lot more of the lower leg and is better suited for nasty pedals hitting the leg from any direction.
One will make your legs hotter than the other- and probably protect better and cost more. It’s up to you how hot and protected you want your legs to be, and if you consider knee protection to be important.
i used soccer shin guards before i got my sixisxone’s for a little bit and they were really bad, go with the sixsixone 4x4’s because they are way better then soccer shin guards, and i think i did a thread on this before you might want to do a search, but im not really sure
thanks for the replies!
@habbywall: Yeah… I found your post :slight_smile: ; But you just said you would try to use soccer guards.
I haven’t got the money for the sixsixones at the moment. so should I wait until I can afford them or should I get soccer shin guards for the time being?
As I see it the soccer shin guards are at about 15EUR, and the sixsixone at 45EUR.
What about these ones? :
http://www.einradladen.net/catalog/product_info.php?cPath=10&products_id=101&osCsid=9e28b3d26afe1b741244c99ded716cda
They don’t seem much bigger than average soccer shin guards but nevertheless they are suggested for trials.
Anyways :slight_smile:
Thanks alot for helping me!
jabbath
those soccer shin guards look like they would work well for riding bc. just turn them inwards.
I found some catchers shin knee guards from my local sports coach. They were free too. I took off some of the extra pieces i didn’t need. They are kinda big but work perfect.
I bought my 661’s for $20. That ain’t bad
