Ok, I’ve taken a few photos. I remove only 1 part and cut and rebuild only that part! Photo #2 shows the cheap squared part I did cut to make the lever. The only problem was ot find one measuring exactly 15mm as the removed lever
Right now I’m mostly wondering what the difference between it and a non-servo wave lever with 180/203mm disk is (when using an adaptor to correct the bar-lever distance). I might get one before the year’s out and do my bit of freewheel testing. At the very latest I’ll buy one when I move to the Qu-Ax freewheel hub…
