I have spent the past several hours trying to fine-tune some V brakes for my Schlumpf 29er with absolutely no success whatsoever.
The symptom was that I could stand the unicycle upside down, spin the wheel and check that the brakes are clear of the rim. They stop the wheel when the lever is pulled, and return to an equal clearance distance from the rim when released.
Sounds good right? Trouble is I would then sit on the unicycle and try to idle it with either foot down, and then one of the brakes would somehow make contact with the rim and try to prevent me from moving the wheel. (Not that idling a 29er makes much sense, but similar foot-forces must come from trying to get the unicycle moving surely).
I looked carefully at the brake pads and somehow they go off centre, so if my right foot is pushing down then the right brake pad somehow moves towards the rim and rubs it. And vice versa with the left foot.
It seems that my foot power is making something flex, most probably the frame.
I have adjusted the cable so the brakes are as wide apart as possible, but the right pad is still rubbing the rim. They are so far apart that only one of the pads seems to touch when I apply the brake when not sitting on the uni and hence seemingly have braking power at all. In other words, useless.
I’ve also made countless other adjustments on everything else, from the height of the moveable brake bosses, the springs that make the brake pads retract equally and even the curved washers that allow the pads to stay at an angle. Nothing works.
I have tried three different sets of V brakes (albeit with the same cable and brake lever) with no improvement. I have spun the wheel round and looking at the rim, it doesn’t appear to meander from side to side so the wheel must be true.
And I have never had this problem with the secondhand Magura HS-33 brakes fitted to my KH 24" XC Muni. They seem to rest closer to the rim, but even when idling on either foot this problem does not occur.
Has anyone else ever come across this? Is it solvable, or am I just going to have to ride a virtual 45" wheel at speed without a brake???
