Matt, Yup, I’ve done it. On a Schwinn/Viscount actually, but I understand
that it is nearly identical to Semcycle’s seat plate. I broke it on a cold
winter day (but I don’t know if it was cold enough to make a difference)
while hopping. It was back when I was first learning to hop so I think I
used my hand to push down on the “nose” of the seat to land.
Jeff
On Fri, 04 Jan 2002 10:14:24 GMT Matthew Macauley
<mmacauley@.hmc.edu> writes: > So I was riding my Sem that I’ve had for a few years, and suddenly, the > plate of metal in the seat snapped in two. Has anyone else had this > happen? I’m sure it can be welded in place again, but it sure was a > surprise. > > Matt Macauley http://www.completejuggling.com > >
GET INTERNET ACCESS FROM JUNO! Juno offers FREE or PREMIUM Internet access
for less! Join Juno today! For your FREE software, visit: http://dl.www.juno.com/get/web/.
the plate of metal in the seat snapped in two. Has anyone else had
this happen? I’m sure it can be welded in place again, but it sure was
a surprise.
Were you hopping or jumping or doing anything that would exert a large downward force on the front of the seat? I did this with a seat that has a plastic plate. It bent and weakened the molded plastic but didn’t break.
If you weren’t doing anything bizarre, I would complain to the vendor from which you bought the unicycle. The part could have had a stress fracture in it when you bought it. If they won’t replace it I think it would be faster, cheaper, and better to buy the plate/seatpost (I don’t know how the Sem seat is made) than welding it unless you can weld it yourself.
On Fri, 04 Jan 2002 10:14:24 GMT, Matthew Macauley wrote: > So I was riding my Sem that I’ve had for a few years, and suddenly, the > plate of metal in the seat snapped in two. Has anyone else had this > happen? I’m sure it can be welded in place again, but it sure was a > surprise.
Mine hasn’t snapped, but it has started to go. There’s a crack about an
inch long on one side. I didn’t notice this until I removed the original
seat in order to replace it anyway.
I’ve heard of other Sem seats snapping, but Semcycle will replace most
parts for free.
Peter Haworth pmh@edison.ioppublishing.com “If a dog jumps
onto your lap it is because he is fond of you; but if a cat
does the same thing it is because your lap is warmer.” –
Alfred North Whitehead
— Peter Haworth <pmh@edison.ioppublishing.com> wrote: > On Fri, 04 Jan 2002 10:14:24 GMT, Matthew Macauley wrote: > > So I was riding my Sem that I’ve had for a few > years, and suddenly, the > > plate of metal in the seat snapped in two. Has > anyone else had this > > happen? I’m sure it can be welded in place again, > but it sure was a > > surprise. > > Mine hasn’t snapped, but it has started to go. There’s a crack about an > inch long on one side. I didn’t notice this until I removed the original > seat in order to replace it anyway. > > I’ve heard of other Sem seats snapping, but Semcycle will replace most > parts for free. > > – > Peter Haworth pmh@edison.ioppublishing.com "If a dog jumps onto > your lap it is because he is fond of you; but if a cat does the > same thing it is because your lap is warmer." – Alfred North > Whitehead >
_________________________________________________________________________-
__ > rec.sport.unicycling mailing list - www.unicycling.org/mailman/listinfo/rsu
I broke my miyata seat base like that. It prompted me to go carbon fiber.
It happened about a minute into an 8 mile total ride, on a 24" The metal
plate cut into my airseat and popped it. It was one of the least enjoyable
rides I have ever had.
>> I broke my miyata seat base like that. It prompted me to go carbon >> fiber. It happened about a minute into an 8 mile total ride, on a 24" > >Whenever that kind of stuff happenes to me or people I’m riding with, it >always happens at or near the point where you’re furthest from the car. > >JF
“To trigger/fool/saturate/overload Echelon, the following has been picked
automagically from a database:” “MILSATCOM, NAIA, Abdelkarim Hussein
Mohamed Al-Nasser”
