This is a fun thread! I have nothing to add about geared hubs, and no criticism of anyone’s ambitions to make them more readily available, but there is one thing which has been bugging me throughout.
Let me just leave this here…
ideal adjective UK /aɪˈdɪəl/ US /aɪˈdiː.əl/
perfect, or the best possible.
ideal noun UK /aɪˈdɪəl/ US /aɪˈdiː.əl/
(PRINCIPLE)
a principle or a way of behaving that is of a very high standard.
(PERFECT)
a perfect thing or situation.
VERSUS
idea noun UK /aɪˈdɪə/ US /aɪˈdiː.ə/
(SUGGESTION)
a suggestion or plan for doing something.
(KNOWLEDGE)
an understanding, thought, or picture in your mind.
(BELIEF)
a belief or opinion.
(PURPOSE)
a purpose or reason for doing something.
John, here are photos from hands shifted Schlumpf hub
There is a small lever attached to the Inside of each crank, a cable is attached to one side of this small lever and goes through the crank above the Schlumpf push button. There is another small lever attached to the frame and controlled by hand and cable.
The guy showed it at Italy Unicon to Kris and Florian, but they decided not to propose it …
I agree - it’s even too much trouble to bother duplicating as a DIY mod for most of us (I have the tools and sufficient skill that I could if I wanted). Any production shifter has to lead directly into the hub via the fixed part which attaches to the frame rather than going via the cranks - which is what bouin-bouin’s design seems to do.
Ahh, it took me way too long to figure out how that hand shifter worked. The lever on the frame rotates into the way of the lever on the cranks which then pull the cable that goes through the crank and push in the button.
So you still only have one opportunity to shift per revolution.
It’s not exactly complicated, but unless you really can’t foot/ankle shift there isn’t a huge advantage either. I would love to have a system that lets you shift at any crank orientation.
Couldn’t you put a small servo in the crank that could pull the wire instead? I don’t know how to wirelessly control said servo, or whether it would have enough torque, but maybe that’s an option? It would be able to shift at anytime, and you wouldn’t have to run more cable.
I think the hub would have to be modded, but it probably could. It might make it even easier, just a coil of wire, magnet, battery and switch. Too bad I don’t have a Schlumpf I could try it with.
EDIT:Anyone have a link to the patent, or other information, so I can see if this is remotely possible.
As I understand it, the shift rod can only be moved when the cranks are in a 6 o’clock position, could be the worst position to start with, but it could be the better as well for the same reason : dead spot = lowest torque, and the shifting process needs this low torque on the pedals to be complete, but in the other hand having suddenly to deal with the second gear at the exact moment you have zero torque power on the cranks could be an issue, in theory.
the “no torque release = no shift” thing is maybe why even with a system that allows to shift (push the shifting buttons) at any moment instead of once per crank revolution, it would still only shift when the torque on the pedals is released.
I was thinking about another crazy system to shift with a lever, radio assisted : a radio commended system installed on each shoe that would “pop up” for a moment, long enough to reach the button without needing any shoe movement.
Personally I use my “ankle” to shift, but maybe because my pedals have enormous grip my fiveten’s are pretty stuck on it, I can not make any foot rotation around a vertical axe
To reach the button with my ankle I have to make my foot rotate in the same way a motorcyclist leans to the side when he rides on a turn, but because my pedals are large I’m pretty far away from the buttons and it’s hard for me to reach it with my ankles.
So, I made some DIY system from two half of a polystyrene sphère that I wrapped with electric tape and that I put inside the kind of pocket you find on fiveten impact high (you can see the pocket on the following pic).
It makes my “ankle” big enough to easily reach the buttons when I bend my foot without adding much weight, and my shifting success rate has dramatically increased.
I am now using larger “polystyrene” extensions than those you can see in the pic (I gave those one to Pierrox), I use the entire sphere cut in two half instead of some bit of it and it works even better.
So we could imagine a system that makes the same job on each foot but without any foot movement, but that’s would look pretty silly I guess
You’re describing a solenoid, which was my immediate thought on seeing the servo suggestion - is a better solution for such an application. The only question is whether there’s space inside the hub to fit such a thing (there certainly isn’t enough space on the ends at the cranks). I do have a Schlumpf, but it’s a first gen so not necessarily representative and in any case I’m certainly not taking it apart to check!
Just about the entire Tour de France peloton uses electronic shifting these days, all but a few too-old-to-change geezer hold-outs. Articles seem evenly split as to whether the derailleurs use servos or stepper motors, which are very different things. I’d say servo motors if I had to guess, since steppers are open-loop and have to be seriously overrated to not lose indexing when they reach their torque limit; both alternatives, too much weight vs screwed up shifting, are quite bad.
Those all use wires AFAIK. Wireless interference between units is probably a big worry in a peloton of 200 riders where they need to work every time right now, but I’m sure it could be made to work for unicycles. Progress in low-power wireless stuff lately has been amazing, and it’d basically be like a PowerTap with data going in the other direction.
It’s likely that wires would work fine for this application as there’s always a part of a geared hub which is fixed to the frame and you could have all of this shifter mechanism attached to that with wires feeding in direct from the frame. Particularly if using a solenoid type mechanism where the moving part floats free, so could be attached to a different part of the hub.
BTW, not that I’m sure how it’s relevant, but I’d be confident that the motors used in shifters on bikes use the same technology as servos - though they will be completely custom rather than off the shelf. All that effectively means is that there’s an integrated sensor feeding back the position and the motor is powered until it reaches the correct position.
A solenoid is a different thing from a stepper motor or a servo. It could be any of those things inside. I’ve got no clue, and couldn’t find any tear-down pictures to even guess from. Those two terms were the ones I saw in the product announcements and reviews. Do you know? The cycle component makers probably have actuators custom made for them, and they could well be some sort of not-fish-nor-fowl hybrid device.
Edit: Replied before I saw aracer’s comments at the top of this page. Agree about custom made and also about some kind of integrated encoder.
Inside a bike electronic shifter? As I wrote before, I’m not sure of the relevance - for shifting a Schlumpf a solenoid would be ideal as one of those works well for shifting something between two positions. Not so good for multiple steps.
