seats
> AlDoug38 <aldoug38@aol.com> wrote in article
> > Sem seats are extremely comfortable! And, you can remove the foam
Tell that to my poor rear end. My sem seat is 2" wide at the narrowest part
which is right in the center at the bottom of the curve in the seat–in other
words, at the bottom of the hill (in the seat–this is probably unclear) where I
seem to end up concentrating most of my weight is only a couple of inches and
the corresponding couple of inches on me is not exactly where I find bearing
weight to be comfortable. If I took the seat off and added washers to change the
angle so that it moved me back farther to the back of the seat where it is wider
and resembles a bicycle seat it would probably be better.
What I have done is taken a pair of thick wool socks (not ones you expect to
use on your feet again) and put them on the seat. The one in front is rolled up
so it looks kind of like a knit watch cap and I try to get the thickest part of
the rolled up part to hit me right against me pubic arch. This tilts my pelvis
back and puts more of my weight on my buttocks on the wider part of the seat.
The other sock goes on the back of the seat doubled over once. It’s nice to
have a little more padding and the extra layer gives the shearing forces
somewhere to slip before they yank on my skin (just like they do when you wear
them on your feet.)
Another good thing about this arrangement is I can put my juggling balls under
the seat between the two layers of the back sock
But it’s still a long way from VERY comfortable. I wouldn’t call it comfortable
at all, except maybe MORE comfortable than some other form of torture.
I doubt, at least for my particular rear end, it ever could be comfortable. It’s
just too narrow. It is very durable though, which is high praise, really. If I
had the means I might go to someone who makes prosthetic legs etc and get them
to custom make a seat.
In the meantime I’ll tru stuffing an innertube in there, too.
ub
Re: seats
John hoy wrote:
> If I took the seat off and added washers to change the angle so that it moved
> me back farther to the back of the seat where it is wider and resembles a
…but the SemCycle seat is adjustable anyway, isn’t it? Just loosen the seat
and slide the front up - this puts your weight on the back - or are you saying
that your seat is already fully adjusted?
Regards, Mark.
Mark Wiggins, | markw@ftel.co.uk +44 (121) 717 6255 Fujitsu Telecom Europe
Ltd,|----------------------------------------- Solihull Parkway, | o Birmingham
Business Park, | In the land of the pedestrian, /|\ Birmingham, | the
one-wheeled man is king. << ENGLAND. | O
Re: seats (and pedals)
In a message dated 98-08-08 17:46:21 EDT, you write:
<< seat may look weird, and a little bumpy, but it’s very comfortable. People
have experienced some problems with keeping the inner tube from popping out the
sides of the seat, but some of us haven’t had that problem. Try it! >>
I solved the “popping out the sides” problem on my SEM by simply duct taping a
12" inner tube together in the center. This gives the inflated tube an hourglass
shape that fits the shape of the seat nicely.
On another note, I’ve been using regular mountain bike platform pedals on my
uni. These have a defininte top and bottom and are designed for attaching cages.
I just bought a set of BMX pedals and what a difference! I didn’t realize how
poorly the platform pedals worked (especially upside down). The BMX pedals
really grip my shoes and make it easier to mount the uni since there’s no top or
bottom to them.
I also got a taste of the “down side” of using BMX pedals … I’m quite sure it
will leave a scar!
Steve Howard Pocatello, Idaho
Re: seats
> Okay, so you use an inertube, but what type? A bike inertube, a pool inertube,
> a unicycle inertube, a car inertube? I really wanna try this idea.
> -Midnight
I used a 20" bike innertube.
Beirne
