This comparison between gapping and high jumping seat in is really interesting. I have no idea what my height seat in is…not very impressive at all though. I think gapping seat in I can go about 1.8m(ish) these days.
i got 17" once long ago, but now my seat is way too high for seat in hopping. i can hop equally far seat in or out, but i think its easier to land a far gap seat in.
busta_gustv do you mean just bouncing and then pop up two feet straight up? If so, wow!! Also, is it only me or should you not be able to gap more than 1.5 feet if you can vertical 2 feet? Just curious.
I’m new to all of this but I started trying to hop differently after riding with KH in Venice, and seeing him clear 25 inch stuff easily despite his head not going more than 15 up during the hop (meaning his vertical jump was only 15 inches). He got the extra ten or so inches by sucking his lower body up once he was in mid air – sort of like a mogal skiier absorbing bumps wihout his head jumping up and down. But here, with hops, the bump doesn’t push your lower body up, you’ve got to suck it up once you lift off. Before seeing and understanding this, I was just trying to literally jump over everything, and nobody can jump too high with a piece of gear dangling off of you.
I think because you can suck the uni up under you much more with the seat out – the uni heigth is not checked by your crotch – you can also hop higher as a result.
Just a few observations. I’ve got a long ways to go befor perfecting any of this, but at least now I’m working with a better concept.
