seat design
I tried my uni out and the seat design is well… horrible. There is NO WAY
I could ride this very much at all. I took the seat apart and discovered that
the padding consists of:
a. A piece of 1" carpet padding trimmed to the exact shape of the seat
b. A VERY thin piece of foam (1/8" at the most) which covers that and is the
“padding” for the sides.
That’s it! The carpet padding is very firm. I may be nuts, but I think a well
padded seat (both on the top and sides) would be much more comfortable. Could
anyone clue me in as to seat design/padding?
The cover is made of 2 pieces: one the shape of the top of the seat and the
other the “side”. There is a seam running around the top edge of the seat.
The sides of the seat also angle outward slightly. I pushed them in a
little…
I assume there are places that one can buy good unicycle seats… In the
meantime, I am going to try some 2" foam…
Dishheads, dishheads, roly poly dishheads!
Re: seat design
In message <m0rkun6-000E24C@dorite.use.com>you write:
I haven’t the foggiest notion about what constitutes a good seat (other than the
input my bum gives me when I sit on it), so I can’t help you, but I had a
question of my own along the same lines: I recently saw an interesting seat on a
bike and was wondering if it could be used on a uni. It was split-seat design
with a pad for each ‘cheek.’ :slight_smile:
It would seem to me that this design would be more comfortable, esp. for men.
I’ve always held that unicycling is a sport better suited to women for obvious
reasons. Perhaps this kind of seat, if feasable, would tip the scales?
                  |  Matthew R. Kenigson kenigson@cs.utk.edu,
                  |  kenigson@freenet.scri.fsu.edu,
—the Neuromancer | reaper@utkvx.bitnet (@utkvx.utk.edu) -------’------;-{@ |
USnail: 3702 Taliwa Gardens Knoxville, TN 37920
| Phone: (615) 577-4942 (home) USA ‘Juggle till you drop’
