Schwinn alignment
you wrote:
>- Frame/wheel alignment (easy to get wrong with a Schwinn)
Could you describe why? I took a look at my Schwinn and I can’t see where the
design would cause any problems.
-Rick
RE: Schwinn alignment
Some Schwinns are better built than others. I think the newer ones are much more
precise in their construction. But still, the entire unicycle is held together
by a single bolt. If the two frame halfs are not lined up perfectly (one not
higher than the other), your wheel can be crooked. The old 1970’s Schwinn that I
converted to a MUni is really poorly made, and requires a lot of work to get it
put together straight.
Stay on top,
John Foss, the Uni-Cyclone http://www.calweb.com/~unifoss/
“Insert clever quote here”
–WebTV-Mail-405517881-10 Content-Type: Text/Plain; Charset=US-ASCII
Content-Transfer-Encoding: 7Bit
Denny, In regards to the Miyata, it sounds like a simple wheel truing problem to
me. Any good “bicycle” shop should be able to true the wheel. Mike
–WebTV-Mail-405517881-10 Content-Disposition: Inline Content-Type:
Message/RFC822 Content-Transfer-Encoding: 7Bit
Received: from mailsorter-101.iap.bryant.webtv.net
(mailsorter-101.iap.bryant.webtv.net
[207.79.35.91]) by postoffice-131.iap.bryant.webtv.net
(8.8.8/po.gso.24Feb98) with ESMTP id CAA02799; Thu, 22 Oct
1998 02:55:19 -0700 (PDT) Received: from
icicle.winternet.com (icicle.winternet.com
[198.174.169.13]) by mailsorter-101.iap.bryant.webtv.net
(8.8.8/ms.graham.14Aug97) with ESMTP id CAA25949; Thu, 22
Oct 1998 02:55:17 -0700 (PDT) Received: (from
server@localhost) by icicle.winternet.com (8.8.8/8.8.8) id
EAA21686 for unicycling-outgoing; Thu, 22 Oct 1998
04:35:17 -0500 (CDT) X-Authentication-Warning:
icicle.winternet.com: server set sender to
owner-unicycling using -f Received: (from adm@localhost)
by icicle.winternet.com (8.8.8/8.8.8) id EAA21620 for
<UNICYCLING@WINTERNET.COM>; Thu, 22 Oct 1998 04:34:41
-0500 (CDT) Received: from auvm.american.edu(147.9.1.2) by
icicle.winternet.com via smap (V2.0) id xma021549; Thu, 22
Oct 98 04:34:13 -0500 Received: from AUVM.AMERICAN.EDU by
AUVM.AMERICAN.EDU (IBM VM SMTP V2R2) with BSMTP id 9243;
Thu, 22 Oct 98 05:37:52 EDT Received: from
AUVM.AMERICAN.EDU (NJE origin NETNEWS@AUVM) by
AUVM.AMERICAN.EDU (LMail V1.2a/1.8a) with BSMTP id 3093;
Thu, 22 Oct 1998 05:37:52 -0400 To:
UNICYCLING@winternet.com Path: auvm!paladin.american.edu!-
zombie.ncsc.mil!newsgate.duke.edu! news.ysu.edu!news-feed-
.inet.tele.dk!bofh.vszbr.cz!newspeer.monmouth.com!newsfe
ed.cwix.com!152.163.199.19!portc03.blue.aol.com!audrey03.-
news.aol.com!not-for-m ail From: miyatauni@aol.com
(MiyataUni) Newsgroups: rec.sport.unicycling Subject: RE:
Schwinn alignment Lines: 11 NNTP-Posting-Host:
ladder02.news.aol.com X-Admin: news@aol.com Date: 22 Oct
1998 02:11:49 GMT Organization: AOL http://www.aol.com
References:
<99BAA0EF4B10D211AC4000A0C95BF9403BA1E7@FMSMSX45>
Message-ID: <19981021221149.27856.00003974@ng110.aol.com>
Xref: paladin.american.edu rec.sport.unicycling:6458
Sender: owner-unicycling@winternet.com Precedence: bulk
Reply-To: miyatauni@aol.com (MiyataUni)
My schwinns both seem to have the wheel centered in the frame… well at
least the schwinn that wasn’t run over by a truck lines up fine, but i have
a big problem with my miyatas. For half a revolution the wheel is within a
few milimeters of the left fork and the other half revolution it’s within a
few millimeters of the right fork at least on the 24"- the 20" is a little
better. Is there any trick to centering it in the forks or are my unicycles
just screwed up that way. Any help would be appreciated, otherwise i’ll
live with it.
Denny MiyataUni@aol.com
–WebTV-Mail-405517881-10–
>to me. Any good “bicycle” shop should be able to true the wheel.
Try plucking the spokes. They should all ring with about the same tone. If they
don’t, your wheel is probably not true.
But, the description of the problem doesn’t sound like an out-of-true condition
to me; he said that it is close to one side of the fork at one position and then
close to the other side when the wheels are rotated 180 degress. That sounds
like a frame alignment problem to me.
I’d still take it to a bike shop. Maybe they can put the wheel on a truing
fixture and check it out.
-Rick
live with it.
