Why would you need the shim? The spacing on my conundrum frame is spot on the KH frames. The bearing holders on the conundrum take 42mm bearings… Am I missing something? No shim needed.
Well thats great!
Maybe I thought it needed a shim because the KH seat post does and 2 sets of bearing shims and frame shims are included with the Counudrum.
Thanks for the help, Ill let you know when its done!
I think I read somewhere that the Surley frames (used to) come with either 40 or 42mm bearing holders. If you’ve got some shims, then it sounds like you have a 42mm frame but you can use the shims on 40mm (ie Profile) hubs. Therefore you should* be ok with the 42mm bearings on the KH Schlumpf hub.
The frame shims will also allow you to fit seat posts thinner than the 27.2mm of the KH seat posts.
STM
In case you’re not, you didn’t hear it from me. I don’t exist, and you never read about it here. Besides, I’ve not got enough money worth suing me for
That’s probably my only gripe with my 24" and 26" conundrum frames. The damn seatpost tube is huge compared to other frames (28.6mm). I HATE using shims and have an aluminum MTB rail post in there right now. I really want a KH adjustable though and may have to suck it up and use the shims.
Just looked in the surly and schlumpf manuals, It looks like everything should be fine. Thanks.
I think im gonna go with 230 mm spokes and gazz 3.0
If anyone has any other suggestions let me know and if not, Peace.
I’ve been LOVING the IRC Kujo 3.0 on my 24" Conundrum. It runs great higher or lower pressure and rolls extremely well on hard pack. That being said, I have never tried the Gazz.
