(Starting a new thread as this seemed more specific than resurrecting the general discussion)
I’m already in the early stages of possibly acquiring a 2nd Schlumpf for a 36”.
It is however a square taper crank mount version. Pre KH, but after the torque arm version - so is using the knurling.
From tons of searching via the interwebs and this forum I believe that this version is still using the 40mm bearings even though it switched to using the knurling (but I am not absolutely sure… anyone know?)
If 40mm am I able to use shims with this to install in a KH frame?
Alternatively I have a spare NightRider Frame (non-magura) which I presume is the later model with machined bearing holders.
I can see that the square taper hub and NightRider frame do appear a more common combo, but the frame has to be cold set to be narrower - and then the bearing holders would I presume still needs to be modified or shimmed to grip the knurling on what I presume are the smaller 40mm bearings.
I have posted a similar question on the Facebook group for Geared Unicycles - but I wanted to ask here in case anyone has had similar puzzlements.
I’m clear on the torque arm version. And know how the KH ISIS muni hub has developed…
But try as I might I can’t find definitive specs for what appears the second iteration of the “first gen” square taper Street Schlumpf hub that looks in photos almost like my M0200 series hub barring the square taper crank mount.
I don’t think I’ll ever ride this 36” set up in any realm of hard core so I am less concerned about crank strength- but the approach to getting this securely set up into a frame seems like the complex / hard to gage step that I would welcome any tips or help on
Thanks in advance!
