Okay. I’ve got 12gb of data that is sitting on a linux file system that I
need to be able to access from Windows 2000 (sp2). The only way I can
access the data now is to go to a command prompt in Windows 2000 and do:
c:>net use \linux.box.ip /user:username :enter password
Then, start -> run -> \linux.box.ip That opens up the file tree.
The problem is that this goes through the internet, capped at 45kb/s -
courtesy of Time Warner Road Runner. I need to be able to access the data
at 10MBit/sec (LAN speed). How can I do this? In addition, how can I
configure Samba to be viewable in the “My Network Places”
> The problem is that this goes through the internet, capped at 45kb/s - > courtesy of Time Warner Road Runner. I need to be able to access the > data at 10MBit/sec (LAN speed). How can I
do > this? In addition, how can I configure Samba to be viewable in the "My > Network Places"
I would try adding a second non-routable IP to both computers (192.168.1.1
and .2 for example) assuming they are both connected via a hub or switch
in addition to your cable modem. That should solve the speed problem.
To make it show up in Network Places make sure they have the same
workgroup and that nmbd is running on your linux box.
“Jon Caruana” <jcaruana@home.com> wrote in message news:9rk0ct$s7o$1@www.t-shirtcountdown.com… > I would try adding a second non-routable IP to both computers > (192.168.1.1 and .2 for example) assuming they are both connected via a > hub or switch
in > addition to your cable modem. That should solve the speed problem.
Thanks for the tip. How would I go about doing that? I’m a
networking newbie.
“Sean S.” <noemail@here.blargh> wrote in message news:9rj411$jqo$1@www.t-shirtcountdown.com… > Okay. I’ve got 12gb of data that is sitting on a linux file system that > I need to be able to access from Windows 2000 (sp2). The only way I can
access > the data now is to go to a command prompt in Windows 2000 and do: > > c:>net use \linux.box.ip /user:username :enter password > > Then, start -> run -> \linux.box.ip That opens up the file tree. > > The problem is that this goes through the internet, capped at 45kb/s - > courtesy of Time Warner Road Runner. I need to be able to access the > data at 10MBit/sec (LAN speed). How can I
do > this? In addition, how can I configure Samba to be viewable in the "My > Network Places" > > – > Sean S. <?$s=“moc.seiticoeg@osomynus”;$s=ereg_replace( > “osom”,“noom”,$s);$s=strrev($s);echo"mailto:$s";?> Hex(RGB) -> > http://thedoh.dyndns.org/hexrgb/index.php
> “Jon Caruana” <jcaruana@home.com> wrote in message > news:9rk0ct$s7o$1@www.t-shirtcountdown.com… > > I would try adding a second non-routable IP to both computers
(192.168.1.1 > > and .2 for example) assuming they are both connected via a hub or > > switch > in > > addition to your cable modem. That should solve the speed problem. > > Thanks for the tip. How would I go about doing that? I’m a > networking newbie.
In Windows XP you go into the Network Connections, select Local Area
Network, Properties, TCP/IP, Advanced and add a second IP to the list. I
think it is very similar for Windows 2000, but I’ve never used it so I
can’t really say.
As for Linux it really depends on what distro you are using, for Slackware
I modified the /etc/rc.d/rc.inet1 file.
“Tony Ranieri” <tony@woogu.com> wrote in message news:9rkidk$rpn$1@www.t-shirtcountdown.com… > you have swat? samba is pretty easy to setup through that… > > – > > Tony Ranieri > - www.woogu.com > > > “Sean S.” <noemail@here.blargh> wrote in message > news:9rj411$jqo$1@www.t-shirtcountdown.com… > > Okay. I’ve got 12gb of data that is sitting on a linux file > > system that
I > > need to be able to access from Windows 2000 (sp2). The only way I can > access > > the data now is to go to a command prompt in Windows 2000 and do: > > > > c:>net use \linux.box.ip /user:username :enter password > > > > Then, start -> run -> \linux.box.ip That opens up the file tree. > > > > The problem is that this goes through the internet, capped at 45kb/s - > > courtesy of Time Warner Road Runner. I need to be able to access the > > data at 10MBit/sec (LAN speed). How can
I > do > > this? In addition, how can I configure Samba to be viewable in the "My > > Network Places" > > > > – > > Sean S. <?$s=“moc.seiticoeg@osomynus”;$s=ereg_replace( > > “osom”,“noom”,$s);$s=strrev($s);echo"mailto:$s";?> Hex(RGB) -> > > http://thedoh.dyndns.org/hexrgb/index.php > > >
“Jon Caruana” <jcaruana@home.com> wrote in message news:9rkl6v$ti$1@www.t-shirtcountdown.com… > > “Jon Caruana” <jcaruana@home.com> wrote in message > > news:9rk0ct$s7o$1@www.t-shirtcountdown.com… > > > I would try adding a second non-routable IP to both computers > (192.168.1.1 > > > and .2 for example) assuming they are both connected via a hub or
switch > > in > > > addition to your cable modem. That should solve the speed problem. > > > > Thanks for the tip. How would I go about doing that? I’m a
networking > > newbie. > > In Windows XP you go into the Network Connections, select Local Area > Network, Properties, TCP/IP, Advanced and add a second IP to the list. I > think it is very similar for Windows 2000, but I’ve never used it so I
can’t > really say. > > As for Linux it really depends on what distro you are using, for > Slackware
I > modified the /etc/rc.d/rc.inet1 file. > > – > Jon Caruana jcaruana@home.com
“Sean S.” <noemail@here.blargh> wrote in message news:9rkmc5$2t9$1@www.t-shirtcountdown.com… > I couldn’t get it set up. It appears that the service is running, but > when I go to http://localhost:901 nothing shows up. > > – > Sean S. <?$s=“moc.seiticoeg@osomynus”;$s=ereg_replace( > “osom”,“noom”,$s);$s=strrev($s);echo"mailto:$s";?> Hex(RGB) -> > http://thedoh.dyndns.org/hexrgb/index.php > > > “Tony Ranieri” <tony@woogu.com> wrote in message > news:9rkidk$rpn$1@www.t-shirtcountdown.com… > > you have swat? samba is pretty easy to setup through that… > > > > – > > > > Tony Ranieri > > - www.woogu.com > > > > > > “Sean S.” <noemail@here.blargh> wrote in message > > news:9rj411$jqo$1@www.t-shirtcountdown.com… > > > Okay. I’ve got 12gb of data that is sitting on a linux file system
that > I > > > need to be able to access from Windows 2000 (sp2). The only way > > > I can > > access > > > the data now is to go to a command prompt in Windows 2000 and do: > > > > > > c:>net use \linux.box.ip /user:username :enter password > > > > > > Then, start -> run -> \linux.box.ip That opens up the file tree. > > > > > > The problem is that this goes through the internet, capped at 45kb/s > > > - courtesy of Time Warner Road Runner. I need to be able to access > > > the data at 10MBit/sec (LAN speed). How
can > I > > do > > > this? In addition, how can I configure Samba to be viewable in the > > > “My Network Places” > > > > > > – > > > Sean S. <?$s=“moc.seiticoeg@osomynus”;$s=ereg_replace( > > > “osom”,“noom”,$s);$s=strrev($s);echo"mailto:$s";?> Hex(RGB) -> > > > http://thedoh.dyndns.org/hexrgb/index.php > > > > > > > > >
“Tony Ranieri” <tony@woogu.com> wrote in message news:9rkmik$3d6$1@www.t-shirtcountdown.com… > what distro are you running? > > – > > Tony Ranieri > - www.woogu.com > > > “Sean S.” <noemail@here.blargh> wrote in message > news:9rkmc5$2t9$1@www.t-shirtcountdown.com… > > I couldn’t get it set up. It appears that the service is running,
but > > when I go to http://localhost:901 nothing shows up. > > > > – > > Sean S. <?$s=“moc.seiticoeg@osomynus”;$s=ereg_replace( > > “osom”,“noom”,$s);$s=strrev($s);echo"mailto:$s";?> Hex(RGB) -> > > http://thedoh.dyndns.org/hexrgb/index.php > > > > > > “Tony Ranieri” <tony@woogu.com> wrote in message > > news:9rkidk$rpn$1@www.t-shirtcountdown.com… > > > you have swat? samba is pretty easy to setup through that… > > > > > > – > > > > > > Tony Ranieri > > > - www.woogu.com > > > > > > > > > “Sean S.” <noemail@here.blargh> wrote in message > > > news:9rj411$jqo$1@www.t-shirtcountdown.com… > > > > Okay. I’ve got 12gb of data that is sitting on a linux file system > that > > I > > > > need to be able to access from Windows 2000 (sp2). The only way I
can > > > access > > > > the data now is to go to a command prompt in Windows 2000 and do: > > > > > > > > c:>net use \linux.box.ip /user:username :enter password > > > > > > > > Then, start -> run -> \linux.box.ip That opens up the file tree. > > > > > > > > The problem is that this goes through the internet, capped at
45kb/s - > > > > courtesy of Time Warner Road Runner. I need to be able to access > > > > the data at 10MBit/sec (LAN speed). How > can > > I > > > do > > > > this? In addition, how can I configure Samba to be viewable in the
"My > > > > Network Places" > > > > > > > > – > > > > Sean S. <?$s=“moc.seiticoeg@osomynus”;$s=ereg_replace( > > > > “osom”,“noom”,$s);$s=strrev($s);echo"mailto:$s";?> Hex(RGB) -> > > > > http://thedoh.dyndns.org/hexrgb/index.php > > > > > > > > > > > > > > > > >
Sure he can he add’s a second NIC to the Computer that is connected to the
Cable modem. He gives that NIC a non routable number and connects it to
his network switch or hub.
> Sure he can he add’s a second NIC to the Computer that is connected > to the Cable modem. He gives that NIC a non routable number and > connects it to
his > network switch or hub.
Yes that would work. I guess I was thinking within the constraints of his
current hardware since it sounds like both computers are already on the
same lan but route through the cable modem to talk to each other.
