Hey there, After suffering the aftermath off some particularly long rides,
I am curious to know where is it I can get a cover for my Miyata seat that
I can put an air tube in? Dustin Zupancic
air seats
If you’re in the US, unicyclesource.com in Marietta, GA has the covers that you seek. Last time I looked at their site, they had them in stock.
> rides, I am curious to know where is it I can get a cover for my Miyata
> seat that I can put an air tube in? Dustin Zupancic
Actually, my family just uses the standard Miyata cover for our air
seats. We just put in a smaller tube, I would guess. we use a 12" x
2-1/2 (I think).
-Max
like what max did i too made a little airseat conversion with a 12x2.25 tube and it works good enough for me for directions on how to do the conversion go to extreme.unicycling.com then go to projects and it is about half way down good luck:p and thanks to nick for the airseat conversion directions thanks man!
If your Miyata is like mine, you already have a suitable cover. Those
covers are only held on by metal clips, easily taken off and re fitted
with the help of a pair of long nose pliers. Inside you will find (
probadly) a big chunk of foam and a sheet of thin foam. Remove the big bit
of foam. find a thin bit of foam ( camping mat is good) to cut to shape
and cover the saet base with ( this should protect the inner tube and if
you get a flat saddle makes it a tad less painfull) Drill a hole in the
saet base where you want the value to emerge. Fold inner tube to fit the
shape of the saddle, cover with the thin sheet of foam that was in the
saddle before, tape that thin sheet to the seat base, replace outer cover
and clip it on again. Pump up air saddle. Ride it and realise you have put
too much air in so let some out till its comfy. Enjoy.
Or you could spend 20 pounds on a nice black leather seat cover from
unicycle.com if you don’t likr the baby sick green and white one.
sarah
Unicycle-Meets , Hockey, Basketball, games & workshops Saturday Oct 27th
and Dec 1st Harry Cheshire High School, Habberley rd, Kidderminster
e-mail stevegrain@aol.com for details
