Saddle keeps wacking out of alignment.
I have a Pashley with a Viscount saddle. Seeing as I’m a beginner I fall a
LOT! Every time my saddle/post gets wacked out of alignment when it hits
the ground.
I a little afraid of trying to tighten it TOO tightly as the hex head or
threads will strip.
Any suggestions?
Christopher Grove
“I never MET a man I didn’t like.” -Will Rogers
Read my short story at: http://www.rosedog.com/manuscript.asp?m=9389256&m-
anuscript=6862016&t=The+Determination+of+Jeffery&fn=Christopher&ln=Grove&-
srdt=9%2F27%2F01+5%3A32%3A05+AM&fs=2&ff=Arial%2C+Helvetica%2C+Verdana&ps=-
4000&s=735143750&folder=Search+Results
Most of the time, I do not overthight the clamp. When the seat is out of
alignment,ie after a big wipe out I just give 2 or 3 punches on the seat
while locking the wheel in place. It works well.
Oli-
-----Original Message----- From: Christopher Grove
[mailto:c_r_grove@yahoo.com] Sent: Wednesday, October 17, 2001 12:34 PM
To: unicycling@winternet.com Subject: Saddle keeps wacking out of
alignment.
the ground.
threads will strip.
Any suggestions?
Christopher Grove
http://www.rosedog.com/manuscript.asp?m=9389256&manuscript=6862016&t=The
+Determination+of+Jeffery&fn=Christopher&ln=Grove&srdt=9%2F27%2F01+5%3A3
2%3A05+AM&fs=2&ff=Arial%2C+Helvetica%2C+Verdana&ps=4000&s=735143750&fold
er=Search+Results
You could try a stronger BMX seatpost clamp. A double bolt BMX seatpost
clamp should work on the Pashley if you aren’t using a seatpost shim.
Check out the clamps available at a bike store that sells high quality BMX
bikes. You’ll be able to find a stronger clamp there.
john_childs
>From: Christopher Grove <c_r_grove@yahoo.com>
>a LOT! Every time my saddle/post gets wacked out of alignment when it
>hits the ground.
>threads will strip.
>Any suggestions?
>Christopher Grove
Get your FREE download of MSN Explorer at http://explorer.msn.com/intl.asp
Why not put a quick release instead of the seatpost clamp ? It allows you
to realign your seat on th field if it gets out of alignement…
Any comments ?
Christ.
> BMX bikes. You’ll be able to find a stronger clamp there.
> john_childs
> >fall a LOT! Every time my saddle/post gets wacked out of alignment when
> >it hits the ground.
> >or threads will strip.
> >Any suggestions?
> >Christopher Grove
> _________________________________________________________________
I don’t know the details on Pashley and Viscount. But we had the same
problem with Jorga’s Showtime 20" which has a quick release that is not
integrated in the frame. Turned out that we had to shift the clamp a
little higher up; at first it was too close to the bottom end of the slits
in the frame to tighten the tube properly. I hope you see what I mean.
Klaas Bil
On Wed, 17 Oct 2001 16:33:38 GMT, Christopher Grove
>hits the ground.
>threads will strip.
>Any suggestions?
>Christopher Grove
>Read my short story at: http://www.rosedog.com/manuscript.asp?m=9389256&-
>manuscript=6862016&t=The+Determination+of+Jeffery&fn=Christopher&ln=Grov-
>e&srdt=9%2F27%2F01+5%3A32%3A05+AM&fs=2&ff=Arial%2C+Helvetica%2C+Verdana&-
>ps=4000&s=735143750&folder=Search+Results
“To trigger/fool/saturate/overload Echelon, the following has been picked
automagically from a database:” “bomb, Sudan, Bagdad”
Thanks all!
Christoher
Quick-Release Seatpost Clamp
FWIW, my new Coker came with a high-quality lever-lock type seatpost clamp that reqires no tools to tighten or adjust. I made sure to tighten it correctly, and have yet to have the seat twist out of adjustment despite my many falls. I’d say a trip to your favorite bike shop for a look at these clamps might solve your problems.:slight_smile:
Most quick release clamps will not hold the post as securely as a double
bolt BMX clamp. With a good clamp the seat will never get out a alignment
out in the field so you will never need to adjust it out in the field.
With a double bolt BMX clamp the top half of the clamp holds the seat post
and the bottom half clamps on the seat tube. It’s untwistable.
john_childs
“Christian St-Pierre” <Christian.St-Pierre@fse.ulaval.ca> wrote in message
news:3BCF074E.22134B4E@fse.ulaval.ca
> allows you
to
> Any comments ?
> Christ.
> > seatpost clamp should work on the Pashley if you aren’t using a
> > seatpost shim.
Check
bikes.
> > john_childs
i currently have a nice noname uni, that came with a 1/4 inch bolt and nylock nut to bolt the seat post in place, this worked well much better than the quick release that i later change it to and then eventually broke trying to get it tighter, definitely go to you local bike shop and get a BMX seat clamp.
