Ok Ok i kno this isnt uni stuff but i kno that alot of you like Bike trials aswell. I just got this awsome Movie! Its called Manifesto which most of you kno is a term used on Trials that means, to eliminate all setup hops. The entire movie is filmed without a single setup hop, its AMAZING!!!
I say that if your looking for a good movie to sit and watch then this is a good one.
I’ve heard about that film, aswell as watching a few clips. and it is amazing I would love to see that.
some one should make a uni vid without any setup hops, maybe I’ll try to make a movie like that, it’ll probly only be like 30 seconds
I would love to own that movie, I like watching bike trials, BMX stuff, and mountain biking, but I don’t even spend the money to buy all the uni videos out there, so I guess I’m out of luck.
Just beware of fads and arbitrary “religions” such as no pre-hops. Ryan Atkins used to be the king of prehops - lots and lots of them - and he still blew everybody away.
Think of slalom ski racing - how it has developed. It used to be all about have your skis parallel, and your feet together. Now you’re losing time if you aren’t skating out of the gate. Since the goal in ski racing is to go faster than everybody else, skating is something you are going to have to do.
The basic idea is that your goal determines your technique. Everything else is secondary.
If your goal is to look graceful, eliminating prehops is a good thing to do. It eventually makes one’s motions much more pleasing to the eye of the observer.
If your goal is to win a trials competition, then grace is secondary. Eliminating prehops may or may not improve your position in the competition. The goal here is not pleasing the observer, but to avoid losing points.
If your goal is to jump higher than anyone else, prehops may improve your height. The goal here is to clear a bar. The bar does not care about grace.
prehops are allowed and encouraged, no setup or recovery hops though. riding manifesto style helps progression as it forces you to be more precise and controlled
Sorry for the terminology. I should have said setup hops. Look at Ryan’s older vids, and you see lots of setup hops.
Eliminating setup hops too early in your riding development may stifle your sense of timing and muscle development. All I’m sayin’ is: don’t start a religion here. Have a lot of tools in your toolbox and learn when to use them.
all i’m saying is setup hops don’t help you at all. The reason you see more in ryan’s earlier vids is he wasn’t as controlled as he is now. if anything, it’ll help your timing not to mention the energy those little pogo hops waste.
In the articles and tutorial section of this forum, I made a little trials guide about getting rid of setup hops.
I have one segment of me doing a lot of them on a tiny line, and it takes about 20 seconds to finish the line, and another shot of me mounting, hop onto the bench, hop onto the table, hop to the other side of the table, hop on the bench, then hop down, no setup hops. =p
I appreciate that point of view, but I don’t agree that it’s necessarily true, for at least three reasons:
for a given person at a given point in their development, setup hops may be the way for them best to handle a situation. So, in a competition, which takes place in time, the rider should handle a situation in whatever manner gives him/her the best chance of winning.
setup hops do cost energy, but they may have benefits too, such as buying thinking time. They use a slightly different muscle set than the bigger hops. They allow blood to pump through your legs better than a still stand. They allow one to change one’s mind mid-line. They may give your legs a better feel for the terrain you are on at the moment in preparation for the next move. They can help you get your pedals in a better position for the next move. So it’s not obvious to me that “they don’t help you at all.”
in Ryan Atkins’ short interview on Defect, he says that when he wants to make a line harder, then he tries to do it in fewer hops. I don’t have the disk in front of me, but I assume that includes setup hops. His typical line now includes up to 1-10+ setup hops per location (See Rails, Big Moves…). The implication here is that the ability to use setup hops makes the line easier. Ryan hasn’t stopped using setup hops as he has developed. Eliminating the setup hops, then, has to have justification, which is primarily aesthetic - it simply looks better - and may actually hurt one’s trials/technical performance in a given place/time.
To me it’s clear that setup hops play a valuable role in riding and that a blanket “manifesto” to eliminate them is inappropriate. However, the effort to do so may be very instructive and add a valuable tool to one’s riding - a tool that can be used when it is the right time to do so.
I really think that the only way to get rid of setup hops is either when you doing an easy line or one that you have worked on before.
I know that when I am doing a new line or trying a different variation of a line, I will either do a few setup hops to point out where to jump form and where to land. Once I get a line down and know exactly what I do, I do it all in one smooth motion, or at least try to.
Also, during natural trials, a few setup hops are good too, landing on rocks and having your pedal or tire in an awkward position makes it hard to jump from it, so about 2-4 setup hops help and get you to the point that you can jump to the next obstacle.
When learning, improvising, doing something new, use some setup hops. Once you know your lines and what you can do, try to get rid of them
I completely dig, and agree with what you have to say.
I DON’T try to get rid of ALL of my set-up hops, unless the line is easy. So, I suppose I take the ‘atkins manifesto.’ If I’m doing an easy line, I’m usually doing it so quick, and I’m so used to it, that I don’t use any set-up hops.
I don’t think set-up hops are an entirely bad thing. I just try to keep them at a minimal. It keeps my head more clear, and focused, and it saves energy. I think that it allows me to be more precise.
My riding has gotten to a point that, by default, I don’t corrective hop much anymore. I see that as a good thing, because I’m not stressing over how many hops I’m doing in a line as much.
Jerrick,
you also put it into realistic terms. I think that Ryan Leech spent something like 30mins, for only 11 seconds of footy, at one point! That’s not very practical.
It’s much more tireing to do it without setup hops or “pogo sticking”. With the little hops in place you can rest, size up the jump, then do it, without those you have to concentrate so much more.
Prehops are when you want to jump higher or further… a prehop is only one hop that you do in the direction you want to jump.
The other gay hops that everyone do are call setup hops.
oh and dont be against manifesto style if you just CANT do it… It’s is a little bit harder but look WAY smoother and I think that important. It also help if you dont want to slip during natural trial.
