Roland Mösl wrote:
> The main problem is, his computer is installed in russian.
> His computer does not display the web sites correct in German or
> English
It seems that everyone involved in this project will need to install support
for Russian, German, and English. Assuming he’s using Windows, this can be
done with the “Windows Update” feature.
On Sat, 06 Dec 2003 15:32:40 +0100, Roland Mösl wrote:
> How to instruct with something on the page to
> display an english or German page with an other char set
> and a russian page with an other?
If you use UTF-8 you should be okay. This can be set in apache’s conf
file, or by .htaccess.
Something like:
DefaultCharset UTF-8
It also helps if you save your documents in UTF-8 format.
