Rollo disks?
Will rollo disks fit onto moment cranks fitted onto a nimbus 2 wheel?
THanks for a reply.
I have another quick question please?
Will rollo disks fit onto Qu-ax lightweight cranks?
thanxs
AS FAR I KNOW, NO!
They have the shape to fit perfectly the Kris Holm Cranks, also the outside diameter. If you put on your cranks, it’ll probably make it worse for flat!
You can try to make some similar stuff in a rotate machine, but would take some hours of work… And you must know HOW to work with it… Altough, the final price will be the same as a Moments Set+Disks!
Rollodisks are for Moments only.
The hub doesnt matter, if the hub works with Moments, it works with Rollodisks too.
